Chevy 350 engine swap – motor mount question - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-04-2007, 03:37 PM
Hello guys, I’ve just bought my chevy 350 , I planning to drop it into my 1978 firebird. I am finally getting to swap out the problematic 231 v6 for this 350 chevy. The engine comes with the TH350 but my current concern is the engine mounts.
The mount brackets are already attached to the 350, but what mounts do I need for the cross member?
The 350 was from a 1974 camaro. Are there any differences in mounts that I need to be aware of?
Thanks guys.
Old 06-04-2007, 03:53 PM
Hippie's Avatar
Last journal entry: HEI comparison.
Thanks guys.
The '74 Camaro should have the clamshell style mounts like the '78 so try setting the 350 down on the 231 mounts, they probbaly won't line up but.......... If not remove the rubber mounts for the 231 from the crossmember and bolt them to the brackets bolted to the block and then set it in place, the correct mounting holes should already be in the front crossmember and it should just be a matter of lining the mounts with the holes and bolting it down. It's been that way on every 70's GM I've ever messed with. I replaced the 231 in a '77 Buick Regal with an Olds 350 and that's how I did it on that one. A little wiggling with a drift punch and BAM they were right on target.
Old 06-04-2007, 04:23 PM
Thanks Hippie for quick reply.
This is a picture of the 350 you can just about see the mounts, they look different to the ones on the 231.
Old 06-04-2007, 04:43 PM
Hippie's Avatar
That's the upper bracket, the actual rubber mount bolts to the frame and then to that bracket. The brackets may be different but the rubber mount on the frame should be very similar. If not just buy mounts for a '78 Camaro with a 305/350. See if you can find a mid 70's Camaro with a small block and see which bolt holes the mounts are bolted to then find those holes on your frame, they should be there, GM was very good about putting all the holes there for the different drivetrain combinations.
Old 06-04-2007, 05:57 PM
By the way.....that's the incorrect method for tensioning the fan belt, the loop goes on the bottom. Otherwise it messes up the airflow to the carb and the pinion-dable valve won't be able to commiserate for it................
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
engine cooling specs for 350 4 bolt chevy downunder Introduce Yourself 2 10-02-2004 10:41 PM
231 engine swap with buick 350 Hot_Rod_Faith Engine 1 12-20-2003 12:20 PM
Need Help!!! 326 Swap with 350 Chevy Engine greg67 Engine 13 11-06-2003 11:44 AM
