Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Chevy 350 engine swap motor mount question
Old 06-04-2007, 04:43 PM
Hippie's Avatar
Hippie Hippie is offline
Last journal entry: HEI comparison.
That's the upper bracket, the actual rubber mount bolts to the frame and then to that bracket. The brackets may be different but the rubber mount on the frame should be very similar. If not just buy mounts for a '78 Camaro with a 305/350. See if you can find a mid 70's Camaro with a small block and see which bolt holes the mounts are bolted to then find those holes on your frame, they should be there, GM was very good about putting all the holes there for the different drivetrain combinations.
