chevy 350 firing order - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-20-2002, 11:36 PM
Post chevy 350 firing order
i trusted some one with some info on firing order for my 350 chevy (70 elco) which was a bad idea and went completely wrong now my wires are off my cap and unable to figure which goes on which even though they are on my spark plugs still but still trying to figure which goes where on my distributor cap because they dont have numbers like the manifold does.im kinda lost soo any help or guidence in the right way because would like to get it up and running again....thanx.
Old 08-21-2002, 01:06 AM
MonteCrl's Avatar
Post
18436572 Thats it. Number 1 is at the front of the cap like this...
4 3
8 6
1 5
7 2
Thats for an HEI distributor
for points move the #1 clock wise one spot and everything elsealong with it
8 4
1 3
7 6
2 5
Old 08-21-2002, 01:09 AM
MonteCrl's Avatar
Post
sory for the jumbled numbers they should be in a circular pattern like the cap but it didnt work
jus think of #1 at 8 o'clock like on a watch for HEI and at 10 o'clock for points
Old 08-21-2002, 11:03 AM
bullheimer's Avatar
NEVER use credit cards!
Post
auto shop 101, okay i'll spend a minute here. first, leave your distributor in the hole. second, take out the number one plug. That would be the one firstest forward, ie the front one on the drivers side. have someone crank the motor while you hold your finger over the hole-slowly, a little bit atta time. when your finger gets blown off the hole you should be near tdc-top dead center compression stroke for #1 cylinder. where ever your rotor is pointing is where you put your number one plug wire at. moving clockwise around the cap you add 8436572. 2468 are on the passenger side on a chebby and 1357 are on the drivers side, now, don't play with your car anymore! <img src="graemlins/boxing.gif" border="0" alt="[boxing]" />
[ August 21, 2002: Message edited by: bullheimer ]
[ August 21, 2002: Message edited by: bullheimer ]</p>
Old 07-13-2004, 05:35 AM
_________
|- Front -|
Engine
1 = 2
3 = 4
5 = 6
7 = 8
Distributor
_1 8
2 = 4
7 = 3
_5 6
|- Driver Passenger -|
Cylinder #1 is on the drivers side front of the engine.
Cylinder #2 is on the passengers side front of the engine.
Old 07-13-2004, 07:01 AM
docvette's Avatar
Wiki Edits: 12
Firing order
[color=yellow]Doc Here
Maybe the photo will help a bit on how it should be.
This is off my Vette,
The battery / Tach hook up side is to the driver's side.
The plug wire with the black tape on it is #1
(2 Nd clockwise from the Battery / Tach hook~up)
The Fire order is: Going clockwise from #1 ~
1-8-4-3-6-5-7-2
The Cylinders on the driver's side front to rear are:
1-3-5-7
The Cylinders on the passenger's Side front to rear:
2-4-6-8
Number 1 on mine is about 5 o'clock... (HEI's) & about 7 o'clock for point type ignition.
Hope this helps!
Doc
[/color]
Name:	firing order.jpg
Aftermarket Solutions
Electronic & Electrical
Innovations
