chevy 350 giving me trouble starting - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-13-2012, 01:56 PM
checkmate427's Avatar
Chevy 350 early 80s crate motor, 240hp 9/1 compression nothing special.
HEI Distrubutor
Timing set at 10 degrees BTDC according to the mark on the balancer, lined up the tower with #1 spark plug to the rotor(which was point toward the #1 cylinder)
How did I find TDC, air rushing out of #1 and both valves are closed.
typical GM Firing order 18436572, double and triple checked them.
Brand new Edelbrock 600 cfm carb, plenty of fuel at the carb.
It has a vaccum advance on the distributor that I've plugged, and both ports for vaccum advance have caps on the carb. I have read it's easier to just plug them when trying to figure out initial startup.
Compression
D --------- P
1 110 2 - 120
3 100 4 - 120
5 90 6- 120
7 100 8 - 120
(cold, obviously it won't start so I can't warm it up first)
Confirmed spark is getting to the plugs.
New plug wires, old ones had zero resistence new ones are ok.
Video of what it's doing when I try to start it:
http://www.youtube.com/watch?v=JyuT1_PjaBE
I'm sure I'm missing something dumb, because this is my first attempt at old school technology.
HELP!
Old 03-13-2012, 03:52 PM
T-bucket23's Avatar
Wiki Edits: 26
Sounds like you dont have power to the distributor when you release the key. Just to test try running a jumper wire to the bat post on the distributor from the + battery terminal.
Also a little more istory on what you have done may help
Chet
Old 03-13-2012, 05:20 PM
That's exactly what it was. Thank a million.
Story on the car is, it's a 1954 Corvette that my Grandfather bought back in 1961. He swapped in a v8 back shortly after buying the car for $300. This is the one he and my grandmother drove and drove a lot putting over 400,000 miles on it. He had over 30 corvettes and was the #5 founding member of the NCRS. Sadly this car sat for 10-15 years due to his failing health. My brother and I inherited the car last summer. Our plan is to get it out on the road where in belongs.
http://www.youtube.com/watch?v=EtL4XemaC-w
Old 03-14-2012, 06:25 AM
T-bucket23's Avatar
Wiki Edits: 26
thanks for posting back, glad I could help. There no always that easy
Chet
starting trouble chevykid08 Engine 2 07-11-2010 01:46 PM
Trouble Starting jim Dunkin Engine 1 03-28-2010 07:38 PM
Starter motor giving me trouble hollywood2k Engine 3 11-19-2006 01:46 PM
LT4 Starting Trouble sibrdav Engine 0 06-09-2003 10:53 PM
starting trouble 85 regal Engine 14 01-29-2003 07:16 AM
