Chevy 350, Has spark and gas, wont run - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-16-2010, 08:58 PM
CoupeDTS's Avatar
First some background. Working on a friends Chevy 350. I helped build the motor so I know everything thats been done with it. We built and put it in back in april. Every single part is new, accessories, tranny, bolts, everything! Of course the block is reconditioned but you know what Im saying. Its a 355, mild cam, summit heads, lots and lots of chrome, 600cfm edelbrock, ebay distributor with a MSD coil etc etc.
So the car has been running great since april. A couple weeks ago he said it was starting to miss or run like s**t. Then a day later it quit running and wont start. Has spark and gas.
He doesnt run it hard at all. Hes only got on it hard a few times. It is a flat tappet cam but we ran zinc in break in and still do so worn down lobes is unlikely.
Even with starting fluid it only putts a couple times. Testing the #1 plug wire it makes a long spark and sparks everytime it should.
I threw in a different module and the part thats connected to it with the wires that go out and plug into the cap but that did nothing.
So I took the distributor out to watch the crank and cam both moving. Those looked good.
What else can I check? Im going to check the pickup coil tomorrow, maybe its off or something.
I guess the one thing that wasnt brand new was the carb. I took it apart and it looked clean so we ran with it. And it worked. Could it really be flooding it super bad?
What am I missing?
Thanks
Old 11-16-2010, 09:37 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
I've seen (and had...) plugs fouled so bad even a hot MSD wouldn't fire them in my blower car. Threw in a new set and fired right off...wouldn't hurt to check them...
Is the carb dumping fuel?
Old 11-17-2010, 05:20 AM
CoupeDTS's Avatar
I took out the #1 plug. It was wet of course. It was a little black but I wouldnt say out of the ordinary? I guess I dont know what a fouled plug looks like? And if they were, how do you prevent that from happening?
Also what do you mean is the carb "dumping" fuel? I can move the throttle and see gas shooting out of the jets.
Old 11-17-2010, 06:12 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
A fresh set of plugs sure wouldn't hurt. I would suggest removing the old plugs, spin the engine over a few times to blow out any excessive fuel, then leave the plugs out for long enough to allow the fuel to evaporate some.
Before starting it, check the timing to see if it has moved. If it has, it could be the timing set (unlikely if new) or the crank gear's woodruff key sheared off in the crank snout.
Also check the distributor gear to see if the roll pin has sheared off. It will likely still look fine, but if it's sheared off, you will be able to turn the gear on the shaft- possibly with a lot of difficulty, because it may still be tight. This doesn't happen often on a SBC, but it can happen, just the same.
Old 11-17-2010, 06:38 AM
CoupeDTS's Avatar
Good stuff, ill look at all that.
Well probably just go ahead and put in new plugs (theyre cheap), reinstall the distributor and time it and see what happens.
I doubt it was too flooded. He tries to start it a few days apart to see if it will run so I would think gas has time to evaporate out.
I have taken apart those 600 edelbrocks before to clean and install a offroad kit, but if I were to take this one apart is there something I should look for as to why it would be dumping in too much fuel? Float levels or whatever that spring and seal thing is on the front drivers side of it? Since it was the only thing that wasnt new on the engine I wouldnt mind taking it apart and cleaning and maybe rebuilding it.
Old 11-17-2010, 07:03 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Be sure the filter is clean and unobstructed and that the fuel pump is set to no more than about 5 psi, and has sufficient volume.
The needle and seat assembly can get debris in it that will cause flooding- you'd see fuel spilling from the boosters if this were the case.
Be sure the floats aren't taking on fuel due to pinholes (if brass) or soaked (if nitrophyl) or cracks (if Duracon, white plastic, hollow).
EDIT- I see this is an Edelbrock carb. So just see that the float isn't heavy. Shaking it will usually tell you- you'll hear it sloshing.
Blow out the passages w/compressed air or carb spray cleaner.
Old 11-17-2010, 07:11 AM
CoupeDTS's Avatar
Should I get the same spark plugs? We just used the basic ac delco ones for a 350. I dont know anything about plugs besides to gap them right. I dont know what fouling is and Ive heard there are hotter ones or something? Just wondering if I should go with a different part number. Ive heard high performance engines use up plugs faster. My 350s have been a little more mild than my buddies here so I havent had to change mine too often. My dad had a 70 GTO he bought new, he said he had to change the plugs every 10-15k miles. My buddies engine has the bigger valves in the heads, probably 64cc chamber, cam is 284 degree i think. I had a 278 cam, this 284 runs a little choppier. Maybe it burns through plugs quicker.
Old 11-17-2010, 07:42 AM
RAYFIN's Avatar
Last journal entry: before picture
Squirt a little regular oil into the cylinders. Could be that gas washed down the walls and there is no compression because the rings arent sealing. Then put in new plugs.
Old 11-17-2010, 08:09 AM
bowtie76's Avatar
I had the same problem. I was running a Holley 650. it was old and rebuilt a few times. But I finally got tired of it and bought a new one. Havent had a problem with it dumping fuel. I had noticed that the fuel/air mixture screws would never stay set and the fast idle screw wouldnt change when you tried to adjsut it. the new carb worked. i woent with a holley 600cfm DP. I also had an issue with plugs in my 350. I had tried to use everything from bosch, autolite, ACdelco and they always fouled out quick. I switched to Accel Shorty header plugs part #8199. They have a U-groove and burn a little hotter. They cost about $30 at the auto store. I havent had an issue since.
Old 11-21-2010, 06:41 PM
CoupeDTS's Avatar
We replaced the plugs. Turns out he had R44T plugs which are for trucks. We went with a R45TS which are for cars and for race cars so we heard. There was a BIG difference in the spark end of the plug. But those old ones were fouled out bad.
After the new plugs it fired right up.
So I learned some about plugs through all this! Always have to learn something..
Old 11-21-2010, 11:32 PM
RAYFIN's Avatar
A 45 is just a hotter plug than a 44.
Old 11-22-2010, 07:23 AM
CoupeDTS's Avatar
I know the heat thing.
But the difference between a T and a TS at the end of the part number is big. The white part of the plug is buried deeper on the T (truck) plugs where its even with the threads. The TS plug the white part sticks up out of the plug. Supposedly the truck plugs are used for heavy duty trucks that use higher torque in the higher RPM range sbc's.
The car runs alot better now also. We couldnt nail down a good timing on it before but now we timed it to the best spot and it doesnt diesel anymore or anything.
I also leaned out the carb some too just for good measure.
So in this case it WAS the plugs though.
Old 11-22-2010, 08:00 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by CoupeDTS
...the difference between a T and a TS at the end of the part number is big. The white part of the plug is buried deeper on the T (truck) plugs where its even with the threads. The TS plug the white part sticks up out of the plug.
The difference between the "T" and the "TS" plug you're describing is the extended tip.
An AC R45TS plug breaks down like this:
R- resistor type
4- 14mm
5- heat range
T- tapered seat
S- extended tip
Old 11-22-2010, 08:05 AM
CoupeDTS's Avatar
R- resistor type
4- 14mm
5- heat range
T- tapered seat
S- extended tip
thanks, good info and link. I feel like crap Ive always just bought plugs for all my 350s and told my friends for their 350s to just pick an early 80s chevy car or truck with a 350 in it and buy delco plugs.
Old 11-22-2010, 09:01 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Well, that's actually not a bad recommendation.
Not knowing what kind of pistons were in another guy's engine, the standard tip plugs wouldn't touch the piston's dome- if it had one. So w/o an extended tip, they'd be a safe bet.
But yeah- if there's no issue w/clearance (which there almost never is these days w/a pump gas fueled engine on the street), the extended tip plugs have a wider 'sweet spot' and are generally an improvement over regular tip plugs.
That said, you'd not want to use extended tips w/nitrous or a lot o' boost, unless you are sure of the set-up.
Good Sparkplugs for 350 Chevy Imaginos Hotrodding Basics 15 04-09-2012 06:36 AM
4.3L chevy doesnt run right after frozen radiator etc, fast68 Engine 13 03-04-2010 07:22 PM
tbi 350 smells like unburnt gas slammedchevy1500 Engine 23 02-17-2009 07:29 PM
blazer has spark at coil and gas no spark at plugs ricksautorestoration Engine 29 02-15-2007 08:30 AM
overhauled chevy 350 will not crank poundst Engine 4 01-31-2004 11:44 PM
