chevy 350 head valve seat pits - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-01-2012, 03:22 AM
hi, i was trying to find out if this can be fixed or does it have to be machined or is it ok.
it has little pits in it i think it had a bent valve in it thanks
ID:	63531   Click image for larger version
ID:	63532   Click image for larger version
Old 03-01-2012, 06:40 AM
Last journal entry: Still running strong
Valve grinding compound/paste.Polish it some,but dont go overboard with it.Spend the same amount of time on all of them.
Old 03-01-2012, 07:27 AM
BOBCRMAN@aol.com's Avatar
Grinding compound will not correct the problem. Only aggravate it. Take the head to a machine shop. Have the valve guide checked and the seat cut with a Serdi type cutter or a well dressed stone. A decent machinist can fix this correctly with minimal material removal.
Old 03-01-2012, 09:37 AM
Bob's right it's a great time to get some really nice 3 or 4 angle valve seats cut.
Old 03-01-2012, 11:34 AM
heads
thanks for the info , took his advice there both at c&p machine getting redone and valve guides thanks again
Old 03-01-2012, 12:08 PM
barry425's Avatar
Last journal entry: Barry's Vega
valve job
Don't be pennywise and pound foolish. The heads are off. Go get a good 3 angle valve job and have them do a pocket port at the same time. You'll end up with no worries and a good running, long lasting pair of heads.
Old 03-01-2012, 12:15 PM
im going to end up building a 383 stroker engine later, but for now im just going to get this one running as my daily driver until i can build the stroker
how do i measure valve seat for valve head diameter? 406 ss monte Engine 2 04-07-2010 09:36 AM
Pits in valve seats 4speed57 Engine 8 11-26-2007 11:37 AM
Valve seat pressure KNanthrup Engine 6 08-09-2005 03:07 PM
Valve Seat Info GoneNova/406 Engine 11 12-03-2004 11:56 PM
Help,with valve seat idea chevtruck Engine 1 08-23-2004 09:09 AM
