Chevy 350-how to identify my engine? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-22-2013, 09:37 AM
I recently bought a 1970 Chevy C10 short bed with 350 engine 4bolt main and yes it is a 4x4.
The engine doesn't look like a 1970 chevy how can I confirm the year of the engine?
Does the engine block has a serial number somewhere that would indicate what year is the engine - if so where is located?
Thank you
Old 08-22-2013, 09:53 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
There are numbers case into the top of the bell housing area, drivers side right behind the cylinder head. There are also stamped numbers on a block pad extending in front of the passenger side cylinder head, if the block hasn't be decked they should be visible.
Get the numbers, poke around these sites and research them
How to decode Chevy Engine Codes
MorTec, Inc. Chevy V8 Engine Crankshaft Casting Numbers List
What makes you think it doesn't look like a '70 Chevy?
Semper Fi
The Following User Says Thank You to 68NovaSS For This Useful Post:
Chevy C10 (08-22-2013)
Old 08-22-2013, 04:19 PM
Silver Surfer's Avatar
More machine than man
Last journal entry: bwaahhaahahaaahhaa
Thank you
Oh you have a 1970 Chevy K10 then.
Old 08-24-2013, 01:11 PM
What do you see that makes you say the engine does not look like its a 1970 Chevy 350?
Most of the external parts are interchangeable between multiple years. Even if its original, it wouldn't be unusual to see a swap to a serpentine belt system, HEI, and other parts from newer 350 engines.
Bruce
4x4, chevy 350, engine identification, truck chevy
Identify 350 chev engine adantessr Engine 5 07-11-2010 04:44 AM
Please help identify my 350 ilcoalminer Engine 4 03-03-2010 08:54 AM
how do i identify a chevy 302 from a 350? coreyk Engine 33 03-13-2009 11:24 AM
Chevy 350 Engine & Trans in a 46 Chevy Pickup Warner Engine 4 02-11-2005 04:44 PM
help identify my sb 350 1984camaroZ28 Engine 5 10-22-2002 06:36 AM
