Hotrodders Bulletin Board
#1
Chevy 350 Intake Manifold Gasket
I have a Chevy 350 crate motor Equipped as follows.
RV Roller Cam High Compression Pistons No PVC Valve No rear engine breather assembly Front oil filler breather only Offenhauser 3X2 BBL carb manifold new My problem is that the rear intake manifold rubber seal to the block blew out causing an oil leaf. When the engine was put together it back fired a few times. What if anything should I check before I take the manifold off to replace the gasket so this doesn't happen again? Thanks Bob |
#2
First of all, throw away the rubber end gaskets, and use hi temp rtv silicone instead.
You need a good crankcase ventilation system. Get the timing set so you will not get any backfireing. Troy __________________ If you don't make mistakes. your not doing anything. 69 ss rs full custom camaro 98 ISCA grandchampion 69 ss rs bb camaro wifes driver 66 Elcamino 350/all dz parts,ac,windows,loaded,my driver 69 ss chevelle bb conv.fresh frame off 26 T sedan street rod |
#3
Check out this thread,and as already said, your motor (engine)
needs to be vented. Best to have an intake and exhaust for your crank case, by way of a breather and a PCV Valve. If you don't have a system on it know, you are creating alot of pressure inside your crankcase, it can cause your seals to leak. If you ONLY have a PCV valve, you will create a vacuum inside the crank case, which can have a bad effect on your oiling system.http://www.hotrodders.com/t42649.html |
#4
I purchased a PVC Valve and a rubber seal for it. A machine shop cut the Valve cover for me. I also got a new gasket set and a tube of RTV High Temp. Thanks very much for your advice. I will be putting ther engine back together this week. Bob
#5
You will need a baffle in the valve cover under the hole to keep the PCV from sucking oil out of the engine.
