chevy 350 intake manifold question - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-13-2008, 07:42 PM
I'm replacing the stock intake manifold on my late '70s chevy 350 small block with a highrise 4 bbl. The stock manifold has a double vent fitting on it (valve cover vent and 350 Trans vent ). The new manifold does not a hole on it for this fitting. What do I do?
Old 02-13-2008, 07:59 PM
poncho62's Avatar
Wiki Edits: 5
Drill and tap a hole in the plenum under the carb base.........or, get a spacer with a fitting in it.
Old 02-13-2008, 09:31 PM
MI2600's Avatar
Member# 3287
Does the carb have a large vacuum port of the rear?
Old 02-14-2008, 07:13 AM
The carb is an Edlebrock 4bbl 1405. The carb is on order.
Old 02-14-2008, 07:27 AM
Double_v23's Avatar
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
Depending on the intake manifold it should have a fitting behind the carb on one of the runners that will work, if not then you can use the large port at the on the back of your new carb when it gets there.
Old 02-14-2008, 05:07 PM
What kind of manifold is it? I've got an Edelbrock Performer RPM, and it has a fitting behind the carb. I put the piece from the stock '73 manifold in there, and use it for the brake booster and trans. modulator.
Chevy 350 bored 60 over, glowing exhaust manifold krenzjr24k Engine 4 08-14-2006 10:15 AM
350 chevy ring end gap question strracer7 Engine 4 11-17-2004 09:26 PM
350 Chevy Starting question ThumperCR Engine 5 10-31-2004 10:37 PM
"Dry" Intake Manifold Question bluesman123 Engine 4 02-11-2004 12:12 PM
73-80's chevy 350 question.. BUSCH Transmission - Rearend 3 02-07-2004 01:55 PM
