Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - chevy 350 into a 1974 international 150 pickup
Old 06-22-2012, 07:56 AM
OneMoreTime's Avatar
OneMoreTime OneMoreTime is offline
Hotrodders.com moderator
Wiki Edits: 3
There are universal motor mounts which get you halfway there as you will need to weld some tabs in the chassis to meet up with the motor side mounts..Wiring may or may not require some wrangling to get that sorted out..Would be better to change both engine and trans as a unit as adapters can get to be a zoo and drivelines are easier to make with the proper ends and in the correct length..
Sam
