Chevy 350 lost power with new intake manifold and carb - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-27-2011, 07:16 PM
valtiel43's Avatar
I have a 1980 Corvette, 5.7 auto. When I first got it I thought it was all stock. It still had all the old emissions stuff on it and everything. I tried to put an Edelbrock Performer for pre-86 sbc's on it, but it didn't bolt up right. So a mechanic I know told me it's because those aren't the original heads on the motor. He said they are obviously post-86 cast iron heads. And that the slightly lumpy idle is infact from a hotter camshaft, and not a motor problem like I originally thought lol. So I ordered a Holley Street Dominator that bolted up good.
So I got the new intake on, topped it off with a new Holley 600cfm double pumper (I know this carb is running good because I ran it on my t/a for a few miles and it worked great). Stuck a Spectre air filter on that and thought I was done. I also threw out the old smog pump, blocked off the egr and crimped the air tubes going to the stock exhaust heads (which will be replaced with headers here soon).
I start it up, get it timed in good because I had to take the distributer out. It seems to be running really smooth. I take it out for a drive and just have no power. I floor it and it's like driving a granny mobile. The car had more *** to it when I had all the old crap on it. What gives? I added the exact same carb and intake to a Monte Carlo with a stock 305 a long time ago and that thing ran like a whole new car. I do it to this 350 and it's like I poured tar in my motor.
My gas pedal felt weird at first, so I took some slack out of the throttle cable, and made sure my springs and brackets are good. My fuel psi is up around like 9, I'm going to get a regulator later and drop it down to about 6 because 9 is super high. I'm also going to see if the timing needs tweaked a little more.
I know this is a wall of text. I'm confused right now as to how my whole powerband could have gotten weaker when I bolted on things that should have brought the power up. If someone reads all this and can help me you will be doing me a huge favor. Thanks
Old 04-27-2011, 07:21 PM
DoubleVision's Avatar
What is the timing set at? What`s the vac advance connected to? A manifold or port vacuum source? 9 psi is too high, I agree it needs to come down to about 6. Are the float levels set correctly? Are there any vacuum leaks?
Old 04-27-2011, 07:27 PM
What type carburetor and intake did you take off of it?
Old 04-27-2011, 07:37 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
I would say bring the pressure down to 5psi or no more then 6psi and tweek the timing and if there are no vacuum leaks you should be ok. JMO
Cole
Old 04-27-2011, 08:13 PM
valtiel43's Avatar
The timing is supposed to be 6 degrees before tdc. I was messing with it for what seemed like forever and never did get the marks to line up on the scale. I used a white paint marker on my balancer to mark where the line is, unless there is two lines on there I'm not sure, but I never saw it line up on my scale. I'll go mess with it more tomorrow as I'm almost sure now that it's out of time.
My Vacuum advance plugs into the port on my carb.
The floats are all set right.
I'm not sure if there are any vacuum leaks. I'll use my gauge tomorrow and check.
The carb I took off looked like the original it was an Edelbrock. The intake was a big cast iron piece. It seriously weighed like 45lbs.
Old 04-27-2011, 08:20 PM
did you make sure to disconnect the vacuum advance and plug the hose while doing the timing?
10-13 deg would be better for timing that engine
Old 04-27-2011, 08:32 PM
Since this is a smog engine, don`t set it by factory spec timing. With the Vac advance unplugged and capped, set the base timing to 12 degrees before top dead center. Lock the distributor. Reconnect vac advance, it should be connected to a full time manifold vacuum source (one that pulls vacuum full time including idle) Recheck timing, it should be 20 - 24 degrees before top dead center. Next check mechanical advance, it should have 36 to 38 degrees, all in by 3000 RPM.
Old 04-28-2011, 07:02 PM
350 lost power
Have someone get in the car and hold the throttle to the floor (ENGINE OFF).
You take your flashlight and look down the carb to make sure the carb is wide open. I fixed one customers car by adjusting the throttle linkage about 1 inch. He had been driving the car that way for 6 years.
Nine times out of ten checking the basic's will fix the problem.
Ron
Will intake manifold make a power difference? proge Engine 3 10-11-2008 10:40 AM
Intake Manifold and Carb Ozz1967 Engine 9 12-29-2005 01:34 PM
4-71 with intake manifold and carb chevyhotrod Engine 3 08-02-2005 02:22 AM
Spacer between carb and intake manifold?... doc_rage Hotrodding Basics 2 02-06-2004 08:40 PM
carb/intake manifold 1969 CAMARO SS Engine 2 06-17-2003 03:20 AM
