chevy 350 making weird noises. - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-07-2003, 09:14 PM
Post chevy 350 making weird noises.
Hey, just recently rebuilt a 350 with a mild cam, stock pistons with new rings and new bearings, using 305 heads. The engine under light acceleration makes a strange sorta rattle noise, sorta like a high pitched metal rattle sound, i don't think it is pinging, but really not sure what pinging sounds like, under heavy acceleration the noise is gone. Sounds like some sort of valve train noise. but not a lifter or anything like that. any suggestions??
Steve
Old 06-07-2003, 10:24 PM
DoubleVision's Avatar
Post
it likely is pinging, 305 heads on a 350 shot the compression up to 10:1, you may want to slow down the timing, see if it goes away, if not, look elsewhere, check the valvetrain, make sure the rockers are in adjustment.
Old 06-08-2003, 08:22 AM
Post
i'm running premium gas and an octane boost but i guess it could still be pinging. it does not sound like a valve train noise though, it's not a clicking noise, it like a metal rattle sound? what does pinging sound like?
Steve
Old 06-08-2003, 12:18 PM
E.T. divided by $ spent= Speed
Post
Yea it be pinging.lol
I had your same setup.You really gotta wtch your timing or it'll ping like a mother.Also watch your temp I went from no stat to a 180 and it seemed to run worse.
Also I seemed to get better performance with R44TS Delco plugs instead of stock R45TS's.
Hope this all helps
