Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - chevy 350 mild motor
Old 10-19-2011, 10:02 AM
SSedan64's Avatar
SSedan64 SSedan64 is offline
Originally Posted by jeremy1992
when you say the cam is installed straight up you mean what exactly?
Straight up = Installed with no/0* additional advance/Retard.
Most Aftermarket Timing Gear/Chain sets have 3-setting positions on the Crank Gear, 4*Retarded, 0* and 4* Advance for the Valve Timing. The Cam Gear can also be adjusted with Bushings in smaller (*= Degree) increments.
