chevy 350 mild motor - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-17-2011, 09:10 PM
im looking at building up a 350 for my truck i would like some descent power and torque like 350hp range its a gen 1 block i would like to keep stock heads 76cc anyone know how i can build it up? like cam size, intake, compression, carb, i also have headders long tube does anyone know of a good combination or any help will do pump gas is a must thanks!!
Old 10-17-2011, 09:24 PM
Last journal entry: 76
For the cam I would say a comp cams high energy 268 it has RPM range of 1500-5500, compression is heads but u said you didn't want to change them so that's out of the question. For the carburetor edelbrock 750 CFM or holley double pumper, there are many good intakes for these carbs if u want a list just ask.
Old 10-17-2011, 09:25 PM
or ex262 cam
Old 10-17-2011, 09:47 PM
Scandinavian's Avatar
http://www.backfalt.fi/indexse
Last journal entry: Torque Converter
This Cam will get you 350hp on the crank if you got a Cr around 9.5-10
a high rise 2plane manifold and 750cfm vacuum secondary.
Do some work to your cylinderheads intake runners and bowls
http://www.lunatipower.com/Product.aspx?id=1984&gid=287
Old 10-17-2011, 10:22 PM
techinspector1's Avatar
Wiki Edits: 326
When I was in Phoenix and had my other computer there, I used to do quite a few dynosim combinations for some of the fellows on here. One of the nicest liittle 350 builds used #12407 RHS bare heads with valves, seals, springs, retainers and locks in a kit, all from Competition Products. The intake runners are 170cc. Use the 1.94"/1.50" valves in a street motor.
http://www.compcams.com/Company/CC/c...x?csid=72&sb=0
I'm thinkin' the heads complete are around $700.00 or a little more. You can't rebuild your junk heads for that.
355 Gen I Chevy street motor, 453 HP, 475 ft-lbs torque.
Block: '68-'86 Chevy 350 Gen I bored +0.030".
Crank: Stock 350, 3.48" stroke, 2.450" main journal diameter.
Rods: Stock 350 5.7". Recommend ARP bolts, re-size big end.
Pistons: Keith Black hypereutectic, part #KB193, 12cc D-cup, 5/64,5/64,3/16 rings. 1.561" compression height. Gap top ring 0.026", second ring 0.018".
Heads: RHS Pro Torquer Vortec 170-64, 2.02" intake, 1.60" exhaust. These heads will accept either conventional or Vortec type intake manifolds. They are drilled and tapped for both types.
Intake manifold: Dual-plane, high-rise such as the Edelbrock RPM, Weiand Stealth or Professional Products Typhoon.
Carburetor: Vacuum secondaries 750 CFM.
Headers: 1 3/4" primaries, long-tube, equal-length. Install "X" pipe between collectors and mufflers. Run 2 1/2" pipe to the rear through mufflers of your choice.
Camshaft: CompCams flat tappet hydraulic 260H: [1], installed straight up.
Rocker Arms: 1.6 ratio on both intake and exhaust.
Static Compression Ratio: 9.6:1
Dynamic Compression Ratio: 8.4:1
Squish: 0.035" to 0.045". Zero piston deck height with 0.035" to 0.045" head gasket or 0.010" to 0.020" piston deck height with Victor Reinz #5746 head gasket that compresses to 0.025".
RPM HP TQ 1000 59 310
1500 103 361
2000 150 395
2500 192 402
3000 246 431
3500 306 459
4000 360 473
4500 407 475
5000 442 464
5500 453 433
6000 450 394
Stock converter and stock rear gear will work, but would be more fun with a converter that stalls at 2000 to 2200 rpm's and a 3.73 gear. The most out-of-whack spec on this build is the fact that RHS flows their heads on a 4.200" pipe. The resulting flow numbers bear little resemblance to real-life flow on a 4.030" cylinder bore. If you want closer to real, multiply these hp/torque figures by 0.95.
If I were going to build this motor today, I'd use a Howards hydraulic roller cam with about the same cam timing events.
Old 10-18-2011, 08:15 AM
Well, being that you said stock gen 1 w/76 cc heads I'm going to assume you want to save some coin. I'm also assuming a TH350 trans w/stock converter and stock rear gears.
A decent rebuild of a 350 with a hydraulic flat tappet Comp Cams 260HE cam, 0.030 over flat top hyper pistons w/2 valve relief(5cc), bored/decked block w/pistons at zero deck, 0.039" gasket, heads w/1.94/1.50 valves w/pocket porting, and Z28 type springs(assuming thats what you have),(should yield about 9.1:1 static comp. ratio, 7.75:1 dynamic CR)(ok for 87 octane gas), a performer type dual plane intake, 600cfm vac secondary Holley, HEI type distributor and pretty much stock everything else should make for over 300 trouble free horse power, good truck low end torque and throttle response and not break the bank.IMHO
ssmonty
PS I have a 260 cam in a 350 and it runs great, 1st is almost a waste of gas as it spins so much with a 3.73 rear end.
Old 10-18-2011, 10:22 AM
1500 103 361
2000 150 395
2500 192 402
3000 246 431
3500 306 459
4000 360 473
4500 407 475
5000 442 464
5500 453 433
6000 450 394
Thanks alot this sounds like a good set up and i have a Manuel 4 speed with 4.11 gears. what do you think about these heads? thanks again!!
http://www.ebay.com/itm/330514277551...ht_7677wt_1037
Old 10-18-2011, 10:25 AM
or maybe some old camel humps?
Old 10-18-2011, 10:42 AM
Banned
The heads you posted are a little overkill for your project but will work. If you go that route you'll probably need a higher stall though, maybe a 2500 or a little more. With those heads, a good intake and headers, a decent carb and a cam with 220ish duration and .500"ish lift you'll probably be closer to 450hp than 350hp. If you stick with a stock intake you can probably knock it down to 370ish hp.
If you really only want 350hp then you can use a pair of heads out of the junk yard, maybe even the ones you have.
Old 10-18-2011, 10:58 PM
Wiki Edits: 326
Those heads are ancient technology and should all be melted down for scrap. L31's are available for cheap and are the best cast iron production head that Chevy ever made in my opinion, far better than the camel hump units.
Old 10-19-2011, 08:47 AM
thank you for all the info it really helps me out and i really appreciate it!
Old 10-19-2011, 08:56 AM
when you say the cam is installed straight up you mean what exactly?
Old 10-19-2011, 09:15 AM
Banned
depending on what heads you have already you may be able to keep those. I dont know if youre wanting to spend $1,000 or $6,000 but for 350hp a lot of different factory heads will work, including camel humps.
you'll need a good dual plane intake (a $70 swap meet item), good 1 5/8" long tube headers ($200-$400), a good 650-750cfm carb (rebuild a used one), a good flat top piston rebuild kit ($500), and a good cam with springs (often included in a good rebuild kit). Machine work costs can vary but you could have over 350hp for less than a new set of nice aftermarket heads.
350hp is NOT a hard target to hit.
BTW, I see you have headers... All headers are NOT created equal, some are great and some belong in the scrap pile.
Old 10-19-2011, 10:02 AM
SSedan64's Avatar
Straight up = Installed with no/0* additional advance/Retard.
Most Aftermarket Timing Gear/Chain sets have 3-setting positions on the Crank Gear, 4*Retarded, 0* and 4* Advance for the Valve Timing. The Cam Gear can also be adjusted with Bushings in smaller (*= Degree) increments.
Old 10-19-2011, 10:53 AM
I use the voodoo 60102 262 cam with a 3000 stall and 3.73 gears in an s-10 and I'm very happy with it. I chose the trick flow 62cc heads because of the price and I'm happy with those as well.
Mild build chevy 350 guts question dadicted Engine 16 10-19-2009 06:26 PM
Chevy Van building mild motor racprops Introduce Yourself 2 09-22-2009 09:16 PM
old chevy motor to new chevy truck pwchevyman1990 Engine 4 03-02-2009 12:36 AM
1971 Chevelle 350 Mild Motor Build seventy3lr Hotrodding Basics 2 02-26-2009 08:27 PM
Can anyone recommend some mild mods for a 5.7 1993 Z71 Chevy truck Axelrod Hotrodding Basics 8 07-02-2004 08:25 AM
