Chevy 350 Motor that squeaks...?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-02-2013, 07:33 PM
Hi Guys,
I got a small block 350 motor that squeaks on the initial start up and will get louder when I rev the motor..It eventually goes away after a min or less...Any idea of what could be causing that? My old ford had the same thing...Could it be the flywheel belts? Thanks for any info...
Old 06-02-2013, 09:00 PM
vinniekq2's Avatar
what are fly wheel belts?
Old 06-02-2013, 09:13 PM
are the belts sliping?
Old 06-02-2013, 09:24 PM
Belts don't feel like there slipping but just that awful squeal when started then goes away...I spray wd40 on them but still the same ...
Old 06-02-2013, 10:38 PM
vinniekq2's Avatar
why would you put wd-40 on belts?
Old 06-02-2013, 10:48 PM
Slammedsi's Avatar
Gotta be a joke right?
Old 06-02-2013, 11:45 PM
techinspector1's Avatar
Wiki Edits: 326
Sometimes I think fellows come on and fabricate a problem just to see if they can get you going.
Old 06-03-2013, 05:41 AM
1Gary's Avatar
Last journal entry: 383 dyno sym
It's the rings.Next???.
Old 06-03-2013, 06:20 AM
It is the belts, get this stuff called Belt Dressing and apply per the instructions.
Old 06-03-2013, 08:32 PM
Sounds normal, just keep reving it up.
Old 06-03-2013, 08:53 PM
Actually that is what a slipping alternator belt does. The belt squeal while there is a high load on the alt. and once the battery charges back up the squeal goes away. I have heard lots of people trying wd-40 for belt dressing, both are equally useless. Nothing in a spray actually fixes a mechanical problem. It might cover it up for a little while but still not fixed.
Old 06-03-2013, 09:52 PM
Thanks for the tip Tresi.....I don't fabricate nothing but simply ask questions to get feedback...I think this site is great and I do appreciate the insight on things I may not have a clue on...I am not mechanically smart and don't have tools to play around with things, but I do what I can...Keep on keeping on
Old 06-03-2013, 09:58 PM
Even WD should have made them quiet, if only for a second.
Old 06-03-2013, 10:20 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
I can't believe anyone would actually recommend putting a lubricant on a drive belt!
Semper Fi
Old 06-04-2013, 05:14 AM
Ummm the alternator does not vary its resistance related to electrical need - it is constant relative to rpm, no matter the load on the charging system.
81 cutlass motor swap for a 350 chevy motor metro0911 Engine 2 02-25-2012 12:55 AM
350 Chevy squeaks after rebuild logan__tille Engine 7 05-24-2008 05:28 PM
What year is my 350 Chevy motor? starneyboy Engine 2 03-02-2007 03:51 PM
1976 Chevy 350 Motor krenzjr24k Engine 12 09-09-2006 06:51 PM
350 chevy motor ridener Engine 3 11-22-2001 10:43 PM
