Chevy 350 MPG help - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-19-2013, 01:38 PM
Silverback's Avatar
Boost Retard
If you were going to go EFI I would seriously consider a late 80's-mid90's TBI swap. It should be about as close to a bolt on to that setup as you'll find, you should be able to get the parts for cheap (should really be cheaper than a 4bbl carb swap unless you get really lucky with used parts), and will get about as good a mileage as you'll get out of it (you can get some killer MPG numbers out of them if you get them working right). The setup is all about low end, efficiency and driveablility and was used in heavy trucks and full sized cars with 305/350 from the factory.
  #17 (permalink)
Old 03-20-2013, 06:23 PM
Thanks for the help guys.
350, chevy, engine rebuild, fuel economy
350 build for MPG? 79bird Hotrodding Basics 6 04-19-2012 02:40 PM
Better mpg from 350 small block Chevy ? Icejeep Engine 10 09-15-2011 08:17 AM
MPG for 350 chevy stanjr41 General Rodding Tech 6 01-04-2006 02:08 PM
what carb has best mpg and performance on 350 chevy? 72chevyelcamino Engine 5 10-22-2002 10:48 AM
350-V8 vs. 454-V8 in Mpg L31chevy Engine 2 10-13-2002 03:10 PM
