Chevy 350 NO POWER - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-12-2012, 10:42 PM
Chevy 350 NO POWER
Whats up hotrodders, well this is the story on my nova
Bought from a widow, car sat in garage for 8 yrs
350 (71" 4bolt main, 4bbl) w/ 305 Heads (4416) , Edelbrock 1407, weiand a xcelerator intake manifold, summit 1103 camshaft, stock dual exhaust exiting behind rear wheels, headers, HEI distributor, Rear Gears not sure ( also never removed the oil that I bought it with, someone told me not to mess with that since the old oil has been in their without change so long that it could damage it with new oil??) HELP
Timing @ 8 degrees, total timing @ 32 idle @ 550 running VR-1 10-30 oil
Problem- Accelerator Pedal feels Hard , also I feel like it has no Power (like it has such a slow start)
Old 09-12-2012, 10:52 PM
RWENUTS's Avatar
First. Change your oil. It won't hurt it.
Second. Bump your timing up to 14* to start. Increase 2* until it pings.
Old 09-12-2012, 11:04 PM
I should change the rear gear oriel, why would I bring the timing up till it pings isn't that bad, what's the purpose of this
Old 09-12-2012, 11:22 PM
Choctaw Bob's Avatar
You may not have enough timing. The only other clue is the hard accelerator which indicates a problem with the carb or the linkage. Examine it and work it by hand, spray some carb cleaner on it. The accelerator pump may be gummed up from old, dirty gas.
Old 09-13-2012, 04:44 AM
I would rev up the engine to 4000 or 5000 rpm and see what the max timing is. I recommend setting max timing at 38 degrees.
Buy an adjustable vacuum advance canister for your hei and set it to add about 12 degrees and use a manifold vacuum source.
You need to figure out the rear end gear. What rpms is the engine doing at 60 mph? What transmission are you using?
With the engine off, have someone push the gas peddle to the floor. Then you look at the carb to make sure that it is opening all the way.
Old 09-14-2012, 05:51 AM
At 3000rpm it's at 32 , I will adjust it 12 today which will get it at 36 and test drive and see from their... I have auto th350.. Will diagnose pedal to metal off and carburator let's see what's up
Also what is needed to remove rear gear oil and what oil should I use
Old 09-14-2012, 08:37 AM
RWENUTS's Avatar
AH!! You where talking about the rearend gear oil!! I thought you meant the motor. I sorry!
Leave the gear oil till later. Get your timing set right first.
Old 09-14-2012, 08:24 PM
Yeah, will
Old 09-15-2012, 10:45 AM
vinniekq2's Avatar
how long did the car sit? old fuel wont make any power in any engine.Does the exhaust have a foul smell?
Old 09-15-2012, 08:43 PM
haust
Car sat for 8 yrs, yeah old fuel was eliminated already and full new tank, also exhaust dkesnt have a bowel smell, just reg carb no catalyt converter smell
Old 09-15-2012, 08:46 PM
I heard it could just be that I might have 2.73 or 3.08 which aren't good at the line and, but good on highway...I have to def find out what gears I have, maybe ill make that my next move
Old 09-16-2012, 06:14 AM
78novaman's Avatar
The AMC, FORD, & CHEVY Guy??!!
Last wiki edit: Improving fuel economy
Last journal entry: Finally on the road
Rebuild the carb. It will corrode and gaskets will harden/leak from sitting.
Check the exhaust/mufflers for restriction (old mufflers rust and plug up)
Put a new air filter on if you haven't already!
how can i get more power out of my chevy small block 350 codyt Hotrodding Basics 4 02-14-2012 07:32 PM
Chevy 350 has no power sometimes bigdog7373 Engine 10 10-31-2010 06:14 AM
Chevy 350 how much power? bigdog7373 Engine 11 07-01-2010 02:42 PM
350 tbi chevy has no power joeplow Engine 1 06-20-2009 09:33 PM
350 Chevy power steering Neophyte Suspension - Brakes - Steering 2 09-21-2004 12:07 PM
