Chevy 350 off-idle hesitation
I'm sure this hasn't been asked before...
The 350 in my 1975 Chevy truck has the stock intake and exhaust manifolds on it, and it has the original 2bbl Rochester carb. Originally it had a hole in each throttle plate that caused a lean condition at idle (for emissions compliance, apparently) making the truck run very rough. My dad fixed this back in the 70's by putting a piece of copper wire through each hole to block them off. Ever since it has had a bad off-idle stumble/hesitation/sag. Fairly recently I had an Edelbrock EFI setup on the truck and it ran beautifully. I took it off to sell seperately (or keep for a potential future project) and now that I've gone back to the carb, the hesitation is back. It happens the worst from a dead stop when trying to take off at a normal (even slow) pace. If I stab the throttle and back off it picks up and goes. To me, that suggests a fueling issue. The problem is, I also notice a pretty bad lug as it shifts from 1-2 and then again from 2-3. That makes me think it might have something to do with the initial timing. The engine does have a recent cam in from when I had the EFI on it. It is a Summit cam (Edelbrock Performer copy). I plan to check vacuum tonight. It idles great, so I don't really suspect a vaccum leak. Should I be running more base timing than the factory 6-degrees? What else should I look for? |
Got any thoughts on ways to compensate for the cam with the existing carb? I'm actually trying to sell the truck and don't want to throw money at the problem if I don't have to.
You could try removing the copper wire plugs your dad put in, up the timing to around 12 and see if that helps any. Worth a shot I guess. You may need to richen up the idle mix (2 screws at the base/front of carb) some too.
I went for the simple, quick fix and cranked the distributor around to 12-degrees of advance. That helped a LOT.
| El Camino Engine - 350 Chevy or 455 Pontiac | bjam2 | Engine | 16 | 08-07-2007 03:45 PM |
| El Camino Engine - 350 Chevy or 455 Pontiac | bjam2 | Engine | 17 | 01-06-2007 09:11 PM |
| Engine build ideas | Rug | Engine | 23 | 12-25-2006 01:39 PM |
| Buick 350 or Chevy 350 | 72Skylark | Engine | 21 | 02-02-2006 02:10 PM |
| New 350 Chevy runns rough and won't idle | 66nova | Engine | 3 | 08-01-2002 01:22 PM |
