I bought a project it is missing some stuff bolts and things I am needing to replace them am having trouble finding the bolt size and length for the oil cooler on a Chevy 350 motor
I am confused about what you are trying to bolt on. There are Chevy's with stock oil coolers, but the only part bolted on the engine is a thick oil filter adapter that has fittings for the cooler hoses. From there the hoses go up to the cooler mounted in front of the radiator.
If you are just trying to bolt the adapter on the engine, you can look up the size of the bolts for a stock 350 oil filter adapter and just trying using some bolts that are a little longer.
Bruce
Related Threads
Hot Rod Forum
2.2M posts
175.9K members
Since 2001
