Chevy 350 oil cooler bolt - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-28-2012, 06:58 PM
I bought a project it is missing some stuff bolts and things I am needing to replace them am having trouble finding the bolt size and length for the oil cooler on a Chevy 350 motor
Old 03-28-2012, 09:49 PM
Chevy 350
Can any one tell me bolt size and length for oil cooler on a 93 Chevy 350
Old 03-29-2012, 04:31 AM
bondo's Avatar
Ayuh,.... That's not a GM Stock part,.... Got a picture,..??
Old 03-29-2012, 04:34 AM
bondo's Avatar
Ayuh,... How many threads have ya started, askin' this same question,..??
As I said in another thread, It's a Non-stock part,....
Got a picture,..??
Old 03-29-2012, 05:17 PM
No picture sorry about 2 post this is my first forum ever
Old 03-29-2012, 06:05 PM
nine4gmc's Avatar
try your local salvage yard, most will let you bring tools and pull the part you need to save money.
Old 03-30-2012, 09:07 AM
I am confused about what you are trying to bolt on. There are Chevy's with stock oil coolers, but the only part bolted on the engine is a thick oil filter adapter that has fittings for the cooler hoses. From there the hoses go up to the cooler mounted in front of the radiator.
If you are just trying to bolt the adapter on the engine, you can look up the size of the bolts for a stock 350 oil filter adapter and just trying using some bolts that are a little longer.
Bruce
chevy 350 turbo trans cooler rollenhard Transmission - Rearend 9 02-16-2010 10:40 AM
chevy 6.5 turbo diesel oil cooler lines jwc Engine 2 11-06-2009 10:59 AM
454 oil cooler adapter bolt sizes darom Engine 2 03-09-2008 09:53 PM
External Trans Cooler, Radiator Cooler, or both? 2004R & 383 SBC Cousin_Joe Transmission - Rearend 1 02-27-2008 09:10 AM
eliminate factory oil cooler on chevy 4.3 v6 77 powerwagon Engine 3 05-13-2005 05:48 AM
