Also go back and check the back edge of the valve covers very carefully. It can leak there without anything visible from the front, but trickle down the back of the engine and create quite a mess.
Bruce |
it looks like that's what it is. if its inside the inspection cover and above it looks dry the rear main may have shifted or one side popped out. make sure all the oil pan bolts are tight
if they were not tightened properly you wont have a good seal on the rear main. i will cross my fingers and hope its a loose pan |
I think its coming from above and leaking down. My oil filter and housing is full of oil as well. I found out my power steering pump was leaking quite badly from the highpressure fitting being loose. I also found that the bolt on the front of the block by the fuel pump was missing as well. I can't see how how oil could be getting from there all the way back behind the engine.
On the oil pan, I used the felpro one piece gasket, and bolts that came with it. I torqued all the pan bolts to what the spec sheet said in the pan gasket kit. I will check the pan bolts again though, and the fitting for the oil pressure gauge again. I did put a mechanical oil pressure gauge on it. |
I think I found it, finally. I went back and checked everything again. The back corner of the driver's side valve cover was wet with oil. Found out that the bolts for the valve cover were loose! I tightened them down, and we will see if it continues to leak. IF it does, I guess I will have to put a new valve cover gasket.
| Cant find my vacuum leak.. | stroker444 | Engine | 10 | 03-28-2010 12:54 PM |
| Chevy 350 oil leak | Dan Denman | Hotrodding Basics | 2 | 11-07-2007 09:27 AM |
| Oil Leak in a chevy 305 | craig_34 | Introduce Yourself | 1 | 12-20-2004 06:18 AM |
| How do I find a vacuum leak? | KeithB123 | Engine | 2 | 09-21-2003 11:36 AM |
| How to find & fix a persistent SBC oil leak | jpd37 | Engine | 16 | 09-15-2003 06:25 PM |
