chevy 350 oil pump priming noise?
ok this is the first time i've builtan engine and i went to go prime the oil pump (with a long screw driver) and some oil came out of a hole on the back of the engine! oops! i need an oil pressure guage! ok so i got that installed it along with the water temp guage. and when i started turing it again it was making a weird clicking noise? what is that? did i screw up in not using a proper oil pump priming tool. and i do relize that im not going to get oil threw the whole engine this way (without a drill) but i just wanted to prime the pump! WHAT IS THAT NOISE?
?? please help! respond very quickly so i can get my nova on the road! |
That noise could be bearings, valvetrain or both. Like you said, only priming the pump isn't going to supply the entire engine with oil on initial startup. When doing it that way you're leaving the oil pump to move oil to critical parts of engine on initial startup. The noise will probably go away as pressure builds but you'd be putting unnecessary wear on the engine early in its life. In order to help prevent this you need to use a priming tool or modify an old distributor as previously suggested and prime the engine with a drill.
ya ive got a west bay auto that sells them so ill try that! thank you
what an oil drive shaft? i didnt build the bottom end but it was done by a local engine shop as there R&D engine! (that built the miss budweiser hydro plane engines) so im guessing which ever one is better? but not sure?
Who is it that did the work? I know of a few shops in the area. Some good, some not so good...
Go read this thread from a few days ago ... it explains HOW the screwdriver is NOT a good way to prime the engine ... new engine oil priming Deuce ... Moderator |
oil pump
When turning the pump they can be fairly ratly until oil goes into pump they quieten up heaps then but can still be a litle clatery. Does it turn without any notches or tight spots. You need to put an old dissy or proper priming tool in as your main oil gallery is open with out it and you cant pressurize the whole system properly. Also may be your oil pump pick up is touching sump making more noise than normal,dont know just an idea cheers
You shouldn't have any problem with their work. They're a little more expensive but I'd rather pay more and have the work done by them than some other places. A friend of mine has taken a couple engines of his to one of the some other machine shops that shall remain unnamed and they've been dickering with him over both engines. They lost the connecting rods to one of them.
I have a 400 block at P.E.D. right now, when I dropped it off they said the only way they were accepting any new work is if I was willing to wait 7-8 weeks. I'm on week 6 now so I'll give them a couple more weeks then give them a call to see if they've made it to mine yet. |
ya this is there accual reasearah and development enginethat they built to test new products hear are the specs! and they dynoed it and every thing!
Specs: Dyno proven horsepower rating of 370.21 @ 5662RPM and 409.1 Ft. Lbs. of tourque @ 3900RPM and with only 9.23:1 Compresion ratio! and it has over 400 Ft. Lbs. of tourque from 3,200-4,300 RPM! Engine specs: 350 4bolt main bored .030 to 355cid steal crank (3.48" stroke) Sealed power flat top -5cc flat top Speed pro piston rings Stock rods with Milodon chromoly Rod bolts all felpro gaskets heads are chevy heads with a stage 2 port job Manley Stainless steel valves 2.02int. 1.50 ex. Comp cams roller tip rocker arms 1.6 ratio int. 1.5 ratio ex. z-28 valve springs Comp cams XE268 camshaft Moroso Chrome oil pan Moroso Chrome valve covers comp cams 84000 series lifters, which are very strong and expencive i painted it chevy orange it was originally black!
| high volume and high pressure oil pumps can destroy cam and distributor gears! | Knobie | Engine | 75 | 02-13-2011 02:22 PM |
| chevy 350 oil filter housing help | briansansone | Engine | 10 | 10-24-2010 12:39 AM |
| Chevy 350: Black smoke, is it oil or gas | STATUTORY GRAPE | Engine | 14 | 06-17-2006 07:07 PM |
| Oil pressure on 350 Chevy | BigMac | Engine | 9 | 09-13-2003 10:01 PM |
| Chevy oil pumps | Knobie | Engine | 1 | 01-16-2003 03:52 PM |
