Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - chevy 350 oil pump priming noise?
Old 04-10-2007, 03:41 PM
chevymastermind's Avatar
chevymastermind chevymastermind is offline
drive it like you stole it!
Last journal entry: engine
ya this is there accual reasearah and development enginethat they built to test new products hear are the specs! and they dynoed it and every thing!
Specs:
Dyno proven horsepower rating of 370.21 @ 5662RPM and 409.1 Ft. Lbs. of tourque @ 3900RPM and with only 9.23:1 Compresion ratio! and it has over 400 Ft. Lbs. of tourque from 3,200-4,300 RPM!
Engine specs:
350 4bolt main bored .030 to 355cid
steal crank (3.48" stroke)
Sealed power flat top -5cc flat top
Speed pro piston rings
Stock rods with Milodon chromoly Rod bolts
all felpro gaskets
heads are chevy heads with a stage 2 port job
Manley Stainless steel valves 2.02int. 1.50 ex.
Comp cams roller tip rocker arms 1.6 ratio int. 1.5 ratio ex.
z-28 valve springs
Comp cams XE268 camshaft
Moroso Chrome oil pan
Moroso Chrome valve covers
comp cams 84000 series lifters, which are very strong and expencive
i painted it chevy orange it was originally black!
