The distributor is a gm hei.
So if I mark it at 36 degrees btdc what do I use as a guide to know where I'm putting my mark? Would it be the marking tabs? Basically would my line be at 36 degrees according to what the tab show 36 to be? I just to a look at it and the tab only goes up to 16 degrees? So how am I'm checking for 36. Last edited by Mrziggy4; 02-09-2013 at 07:43 PM. |
GM HEI ![]() How many million more times do I have to repost this picture |
a circle is 360 degrees. 36deg is 1/10th that.
therefore 36deg from TDC on the balancer is 1/10th then way around the circumfrence... figure it out. grade 8 math... google it. |
Ok thank you
read my post #3 here
initial and total timing |
I had the same problem with my T-Bucket that I bought. It has 2 new Edelbrocks on a tunnel ram on a BBC.
You can download a carb tuning manual from Edelbrock. That's a pretty big cam for the rest of your combonation as others have brought up. I think I would start with a vacuum gage and check to see how much vacuum the engine is pulling. Both your carb and distributor works on vacuum and the big cam doesn't put out much. As those carbs come from the box they need around 12 inches of vacuum to seat the rods against the springs. If vacuum is bouncing around at idle, you should be getting over rich mixture at idle. Edelbrock sells spring kits to adjust these. Others have suggested changing to a Holley or Demon type carb. They still have power valve issues but they are easier for some to deal with. The Edelbrock can be tuned to be reliable but it may take a cam change to make it work. This might be the best solution. Something like the old 350 HP 327 has a bit of a thump to it and still is a lot easier to live with on the street. I had to change the cam on mine to make it livable on the street. |
| Edelbrock carb on a Chevy 350 | tsettl | Hotrodding Basics | 5 | 02-28-2012 10:45 PM |
| Edelbrock carb problem | MJS69 | Engine | 15 | 11-30-2011 02:38 PM |
| edelbrock carb problem | thelastdon15 | Engine | 4 | 10-07-2008 08:22 AM |
| Edelbrock Carb problem? | busterwivell | Engine | 9 | 07-29-2007 07:49 AM |
| Help, another Edelbrock Carb Problem | xxllmm4 | Engine | 3 | 07-07-2006 06:12 AM |
