chevy 350 on propane wont start!!!!??????? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-13-2010, 07:35 PM
the truck has been sitting for almost a year, ran great when i parked it but when i went to fire it up yesterday it just cranked and cranked without so much as a sputter or a pop. i pulled off the line to the condenser and got lots of propane so im thinking the problem is sonwhere between there and the mixer. im fairly new to propane so any help or advice will be greatly appreciated thanks
Old 08-13-2010, 07:42 PM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
I don't know anything about propane but did you make sure you have spark ?
Old 08-13-2010, 07:51 PM
im fairly certain its a fuel problem because ive been cranking it for a good minute straight and i cant smell any propane at all
Old 08-16-2010, 05:17 AM
tnsmith10's Avatar
when will it rain???
propane has a tendancy to get gummed up like gas if it sits too long. its a good possibility that its plugged things up at either the exchanger or the "throttle body"
best i can recommend is to close off the tank valve and unhook the line from the tank to the exchanger and blow out the line. after that, the exchanger will have to be opened up and cleaned out. and then after that, the throttle body will need to be removed and all passages cleaned out thoroughly.
Old 08-16-2010, 07:06 AM
Last journal entry: Bringing home the 401 Nailhead
My only experience with propane is with forklifts so this may not apply in your case. Some forklifts have a "regulator" with a valve that opens with vacuum. The cranking supplys the vacuum. If the engine does not crank fast enough or there is a vacuum leak, etc the valve does not open hence no fuel to the engine. Some of these were solenoid actuated also. If so check for power to the solenoid.
Putting a Chevy 350 in a Buick Buicks-and-Blatz General Rodding Tech 3 07-11-2010 02:08 PM
Hi. just wondering why the 350 chevy small block is so good... judgedredd Hotrodders' Lounge 78 06-25-2010 08:01 AM
350 chevy wont cold start J. E. Allison Engine 8 02-18-2010 06:59 PM
El Camino Engine - 350 Chevy or 455 Pontiac bjam2 Engine 16 08-07-2007 03:45 PM
72 Chevy truck 350? for monte 1stTimeDoingItRight Engine 6 04-13-2006 06:40 PM
