Chevy 350 Rod and bearing clearences???? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-30-2008, 12:15 PM
JD's camaro's Avatar
J-Man
Last journal entry: Camaro project
Chevy 350 Main and Rod bearing clearences????
I have a chev 350 4-bolt 2-pc rear seal, out of a 77 camaro. I'm getting ready to put bearings back in. I have read a few articles on bearing clearances for main & rod bearings. I'm looking for a spec sheet or if anyone knows of a webpage that might have the correct tolerances for main, rod bearing clearances, and rod to rod clearance, torque spec for studs and bolts,have windage tray.Maybe a tip or two on selecting bearings. I know I could go get a book. Thought I would try
the forum first. This place has been good to me.
The crank is 10-10.
Someone forgot to use plastigauge the first time. Spun a rod bearing and chewed the rest. Under 300 miles on a balanced bottom end. The engine only saw 5900rpm twice. I'm back to another crank and a new set of bearings. And a nice set of micrometers, bore gauges and telescoping gauges.
Any help on this would be appreciated.
Old 07-30-2008, 12:30 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
You should find what you need here.
Good luck,
Rich
http://www.google.com/search?client=...=Google+Search
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 07:57 PM
Junkyard Motors.. Zartan Engine 20 07-08-2011 08:52 AM
Need help finding a rod bearing for the youngsters Hot rod 62CHEVYC10 Engine 2 04-10-2007 08:54 PM
Building A 302 Chevy Scorpio Shaping Flow Hotrodding Basics 6 01-16-2007 06:55 AM
Spindle interchanges bskaggs Suspension - Brakes - Steering 11 06-05-2006 02:29 PM
