chevy 350 running rough - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-26-2011, 07:06 PM
I just got the engine back in my truck after some frame straitening and now its running rough. it was running fine before i pulled it. it starts and idles ok now. but when i rev it it kind of stalls and then slowly revs up. it sounds like its missing on a cylinder, but i checked all of them and there all firing.
recent tune up about 1000 miles before it was pulled. plugs, wires, cap, rotor.
i got a 15 to 17 vacuum reading. timing is at 5 atdc. compression ranges from 135psi to 150psi. isnt running rich or lean from what i can tell from the plugs and exhaust.
completely stock chevy 350 in a 1979 chevy 1 ton.
im a little confused on what it could be. im a diesel mechanic and have forgotten most i learned about gas engines.
Old 03-26-2011, 07:10 PM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
Your timing needs to be at 12 to 14 btdc, with the vacuum disconnected . Go from there. Allan
Old 03-26-2011, 07:31 PM
18436572 just in case a wire or two came off and went back on in the wrong spot
Old 03-26-2011, 09:39 PM
im assuming by "disconnect the vacuum" you mean the vacuum advance on the distributor and plug it.
after i did that i had 6 to 7* btdc. then adjusted the distributor so the timing was at about 14* btdc.
it runs better than it did before i pulled the engine except for the short stall before it revs. maybe the accelerator pump? it doesnt pump as much as it used to when you look down the carb and pull the throttle, but it will still flood the engine if you pump it too much.
i rebuilt it not that long ago with all new gaskets and accelerator pump.
Old 03-27-2011, 10:53 AM
adantessr's Avatar
'23 T-Bucket Pickup
Wiki Edits: 3
It does sound like a problem with the accelerator pump. Maybe the pump checkball is stuck. JMO
Old 03-27-2011, 12:32 PM
bondo's Avatar
Ayuh,... I agree,... Might even be the fuel Filter,...
305 running rough 400smb_s10 Engine 1 02-27-2011 09:04 AM
Chevy 350 running rough at idle The Raven Engine 3 01-07-2010 03:54 PM
chevy 350 crate engine... backfiring and running rough strays Engine 20 10-23-2009 09:05 PM
Chevy 235 missing/running rough countryboytn Engine 15 09-30-2009 09:55 PM
chevy 4.3l help-detonation, running rough briansansone Engine 4 03-20-2007 07:14 PM
