Chevy 350 running rough at idle - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-06-2010, 11:09 PM
I have a 350 in my 1982 chevy pickup and it runs rough at idle but runs fine when I am driving. I just put a new 2400 stall torque converter on the truck and recently put a edelbrock 1406 carb on it. One day it seems to be idled up to high and then it seems to be idling to low when I think I have it right. Can this problem be from timing, Carb adjustments or what I appreciate the help.
Old 01-06-2010, 11:17 PM
DoubleVision's Avatar
Get a vacuum gauge and set the idle mixture screws to the highest vacuum level in park. Try to get them even as possible. Lightly seat them all the way in then back out until highest vacuum is acheieved.
Old 01-07-2010, 03:06 PM
Thanks
Thanks Double Vision I will try that but the truck ran pretty good today. It was qutie a bit warmer today than it has been the last couple of days. Dont know if that had anything to do with it b/c it still idled rough after about a 20 min ride in teh Interstate but I will try the Vacuum gauge Thank a lot.
Old 01-07-2010, 04:54 PM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
It sure sounds like you've got a vacuum leak somewhere, maybe carb baseplate gasket?
buick 350 - chevy 350 72buick Engine 23 10-13-2009 09:38 PM
SBC 350 running very rough at idle 75gmck25 Engine 3 02-03-2009 06:38 PM
chevy 4.3l help-detonation, running rough briansansone Engine 4 03-20-2007 08:14 PM
chevy 350 stalls stape Engine 8 12-07-2003 01:16 PM
Rough Idling 350 chevy Waterhead Engine 9 02-23-2003 06:50 PM
