chevy 350 runs good then backfires under load - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-30-2013, 09:13 PM
68 firebird's Avatar
i have a chevy 350,standard bore engine,4 bolt main.comp cam 270 h-10 grind.edelbrock 600 carb.410 gears,4 speed saganal tranny in a 68 firebird...engine runs good then out of nowhere it starts to backfire under load.after it has run for about a half hr.ran good all last year.just startind doing this.i would be thankful in any body can give me a direction to go to figure out the problem.can this be timing or carb.thanks in advance for your comments
Old 04-30-2013, 09:19 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Simple first, have you looked at the dist cap for moisture, crud on the tower contacts, cracks or carbon tracking? Vacuum leaks?
Semper Fi
chevy 350 backfires out intake. what causes this glhx Engine 4 07-08-2010 05:03 AM
73 Gran Torino Sport 351W 650 Holley Backfires when under load. 73Torino Engine 11 11-30-2009 03:15 PM
sbc 350 w/ holley 650cfm.. cant get good throttle response and backfires.. HELP pleas deanedge1 Engine 15 11-20-2009 08:16 AM
350 chevy engine backfires thru carb toms1940chevy Hotrodding Basics 8 09-23-2009 08:24 PM
350 won't start, backfires, starter smokes, runs rough... 1970customcamper Engine 3 09-08-2009 09:57 PM
