Chevy 350 small block type. - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-22-2008, 08:04 PM
80 SS El Camino
Hey guys.
I just bought an 80 El Camino. These did not come with 350's, only V-6 and 305. The gentleman I bought it from knew nothing about the motor. Though strong, I need to know if there is a way to track the type of motor by a number stamped on it. What I'm looking for is whether it's a 2 or 4 bolt, what year it was made and that should lead me to the H.P. it had from the factory. It would be a bonus if I found out the pistons size too, if anyone thinks they could push me in the right direction that would be great. Thanks
Darrin
Old 06-22-2008, 08:53 PM
327NUT's Avatar
the '80 305 sbc was rated at around 145-155 hp, There were NO 4 bolt main 305's....now I'm sure somebody will come on here and say "hey, I,ve got a 4 bolt 305" !!! For a lot of real info just google 305 chevy horse power specs.
Old 06-22-2008, 09:11 PM
is destroking for dragrace good or not
i have 350 with a 305 crank what does it make it
Old 06-22-2008, 09:14 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
dedub, information you need to determine information about your engine can be found at these sites:
http://www.nastyz28.com/chevy-engine-code-stampings.php
http://www.chevymania.com/
http://www.mortec.com
Originally Posted by Mortec.com
460778.....305...78-79...2 or 4, some Canadian assembled heavy duty truck blocks have 4-bolt main caps
SSedan64's Avatar
Look on the machined surface just in front of the passenger side head when looking straight down and you should see the VIN suffix code.The last 2 or 3 letters will give some info. Also look at the driver side rear of the bellhousing mounting surface behind the driver side head for the casting number.
http://www.chevymania.com/partsid/su...fm?block=Small
http://www.chevymania.com/partsid/pa...=block&block=S
http://www.mortec.com/
Blazin72 I knew before I finished typing someone would've answered.LOL!
Old 06-22-2008, 09:46 PM
327NUT's Avatar
Ok you're right, my info was from "Chevy High Performance" mag. I was just refering to his El Camino having a factory 305 4 bolt, don't consider it a "heavy duty truck" ....but you are correct.
Old 06-22-2008, 09:49 PM
Blazin72's Avatar
Wiki Edits: 19
Nah, I was just giving you a hard time anyway.
Old 06-22-2008, 10:00 PM
327NUT's Avatar
edited due to lack of knowledge.
Old 06-22-2008, 10:50 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
The 350 and the 305 crank are both the same stroke, 3.480", so it's still a 350.
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
oil presure for 350 small block chevy squiggy2000 Engine 6 08-19-2006 02:59 PM
96 chevy 305 vortec heads on 350 block badriand Engine 6 02-20-2006 07:45 AM
Need Info On 72 Small Block Chevy impala59 Engine 5 10-01-2003 05:11 PM
chevy 350 small block mount bolt torque v9kotch Engine 4 09-18-2003 12:46 PM
