We're winning the case!
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 08-26-2007, 03:21 PM
bccsrc bccsrc is offline
Chevy 350 Stock Intake - Bolt Removal
I have a 82 Chevy 350 with a stock intake and I'm trying to remove 2 bolts by the EGR that I can't get a socket or end wrench on. What was Chevy thinking? I can post a picture to show you what I'm having trouble with.
What should I do? I don't want to strip the intake bolt head off...
Old 08-26-2007, 03:44 PM
Jmark's Avatar
Jmark Jmark is offline
Would removing the EGR help gain access? Or a really good 6 point box end wrench? Or a thin wall 6 point swivel socket?
Always on the look out for cheap Nike shoes!
Old 08-26-2007, 04:35 PM
I got it by using a screw driver and a hammer.
The back side is touching the intake. There was no way to put a socket on it. There wasn't enough bite to get it with an open end wrench either. I'm changing the intake to a Performer RPM, so at least I wont have to worry about it anymore.
Old 08-26-2007, 04:50 PM
techinspector1's Avatar
techinspector1 techinspector1 is offline
Senior Curmudgeon
techinspector1's barnstar
Wiki editor
Last wiki edit: Threading tips
Wiki Edits: 210
Why the RPM model instead of the standard model? Are you planning further modifications that will support the larger volume of the RPM? If not, I predict the car will be slower than it was with the stock manifold due to less power under curve where the motor is normally driven.
In other words, the motor might make a little more total hp at the top of the rpm range with a RPM manifold, but that's not where the motor operates 95% of the time. With the bigger manifold, you're giving up much of the lower rpm torque because the increased volume of the manifold will slow down the mixture at low r's, thus decreasing cylinder filling to less than the stock manifold. Result-slower car and lighter wallet.
Old 08-26-2007, 05:03 PM
I do plan on running Edelbrock Heads, and the matching cam. That should help shouldn't it?
Old 08-26-2007, 06:01 PM
Senior Curmudgeon
Wiki editor
Wiki Edits: 210
In a word, yes, as long as you increase the static compression ratio at the same time to support the longer cam.
Reply Back to top
« test | weaind 8004 »
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Chevy 350 Stock Intake - Bolt Removal"
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 47 05-01-2009 11:14 AM
Chevy 350 Crankshaft bolt removal 75gmck25 Engine 11 03-14-2008 06:27 AM
Stock 350 4bbl Cast Iron Intake Dimensions Houman SS '70 Engine 18 05-14-2005 04:06 PM
Stock eliminator 78 monte Engine 5 01-02-2003 05:10 AM
Stock Chevy 350 LT1 in a 50 Chevy PU bthaxton Hotrodders' Lounge 1 06-30-2002 08:05 PM
