Chevy 350 supercharged - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-07-2010, 06:31 PM
I have a 72 chevelle with a stock 350, for the most part it just has headers, holly 600cfm carb, intake and a pertronix distributor. The motor is a new crate engine from Autozone. Can I supercharge it without changing the cam and going all crazy? If so tell me how and how much?
Old 08-07-2010, 09:07 PM
Semper Gumby
Wiki Edits: 2
Which "new crate engine" ?
What specs?
What is the static compression ratio?
What cam?
Which heads?
Which pistons?
Is it the 175 hp one? The 250 hp one? The 275? the 300? the 325? the 350 hp 350?
You have an engine that MAY have low compression or very high
It MAY have cast internals, it MAY have some forged stuff.
It MAY be a motor that will work with a "huffer", but it most likely won't.
You are sort of asking such an open-ended question that there is no answer at all. As to "how much?" - well - how much $$$ have you got?
finally finished chevy 350 build redneckrodder Engine 7 05-30-2011 06:03 PM
350 chevy heads question pena0724 Engine 7 03-02-2009 06:09 AM
350 chevy pena0724 Engine 2 02-17-2009 08:04 PM
350 Chevy in a '73 TransAm Lawngodfather Engine 6 06-10-2008 08:08 AM
El Camino Engine - 350 Chevy or 455 Pontiac bjam2 Engine 16 08-07-2007 03:45 PM
