Ok, tried bypassing the ignition switch as recommended above, still the same issue.
Gas tank is almost empty. We are going to put in gas that has no Ethenol content and see if that makes a difference.
We are also going to run a hose from the can to the pump to bypass the existing lines that have always been in the same location. It would be strange that we would get vapor lock now without it ever being an issue in the past. The car was here in Florida for 4 years without issue, then in Georgia for 2 years and now back here in FL. The idling issue only showed up after coming back to Florida.
