chevy 350 tbi pinging - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-18-2008, 02:55 AM
bone stock lo5 roller motor rebuilt tbi new fuel pump and filter new reman. dist. and coil timing at 0 new custom chip for daily driver from tbi chip drinks 89 octane pings hard under load any ideas out there???
Old 05-18-2008, 04:26 AM
DoubleVision's Avatar
Whats the fuel pressure? how many miles are on the injectors? Have the injectors been replaced? Is the EGR still functional? When the pinging occurs can you ease down more on the throttle but the engine seems to not pick up any power? Or does it seem to have more and ping less with less throttle?
Mine had this issue, I replaced the stock injectors with Venom units, reset the fuel pressure and it made a big difference.
Old 05-18-2008, 11:06 AM
tbi rebuilt by affordable fuel injection injectors were rebuilt and tested. tried two fuel pumps. i agree has to be a lean condition now what??? egr gone block off plate no vacuum leaks egr taking off of chip tune
Old 05-18-2008, 12:36 PM
not an expert but i thought the egr acctually fends off detonation by cooling the cylinders a little im not sure that was the best thing to do with removing the egr
Old 05-18-2008, 01:16 PM
biggeazy-e's Avatar
EGR is actually used to lower NOx emissions, it does fight detonation/spark knock, but that isn't its sole purpose..
El Camino Engine - 350 Chevy or 455 Pontiac bjam2 Engine 16 08-07-2007 04:45 PM
Engine build ideas Rug Engine 23 12-25-2006 02:39 PM
Buick 350 or Chevy 350 72Skylark Engine 21 02-02-2006 03:10 PM
305 tbi into an older 350? help... NOSBOSS Engine 2 03-23-2004 10:45 PM
89 Chevy P.U. TBI ????? catdad2u Engine 1 11-12-2002 03:52 PM
