Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Chevy 350 Timing
Old 01-22-2006, 10:30 AM
engineczar's Avatar
engineczar engineczar is offline
actually that would be advanced if it was on the other side of the water pump
make sure the vacuum advance is disconnected and plugged if there is one, see if you can get the timing down to the 10-14 (or less depending the distributor) advanced range and set your idle speed. You should be able to turn the distributor 15 or so degrees unless the vacuum pot hits the manifold
