Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Chevy 350 Timing
Old 01-22-2006, 01:40 PM
poncho62's Avatar
poncho62 poncho62 is offline
Wiki Edits: 5
Are you sure that you have the right damper on it?.....The early 80s SBs had the timing mark right on top, so you looked down between the water pump outlets.
Check your damper for TDC (top dead centre)
Ontario Rodders
