Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Chevy 350 Timing
Old 01-22-2006, 08:05 PM
Chevy 350 Timing
Aloha xntrik, poncho82, onovakind, engineczar
Thanks for all the good help. The tip on "rotor phasing" I think it helped the most. I moved the distributor over one notch on the oil pump drive. The timing mark is now about 8-10 degrees closer to the pointer, almost straight up and almost hidden by the water pump. I am checking it at around 800 - 1000 rpm with the vaccum advance disconnected and plugged. The motor runs better.
My next move is try "manual timing". Here's how a friend explained how you do that:
1.) retard until it runs rough at idle,
2.) advance to where it smooths out,
3.) run to 160F - 180F and listen for pre-ignition pings going uphill in drive,
4.) if there is pinging, retarded it a degree or two.
Two questions:
1. Is that a good way to do it?
2. Would moving the distributor another notch make things better yet or would it make them worse?
