Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - chevy 350 timing
Old 02-07-2006, 08:53 AM
stanjr41's Avatar
stanjr41 stanjr41 is offline
chevy 350 timing
I finally got rid of all the gremlins and am ready to set things right.The drivetrain consists of a rear end/with approx. 3.90 gears;a 350 turbo trans.The engine consists of a 260 h.p. g.m. goodwrench longblock,w/a performer manifold;a 600 holley carb/with jets changed from #64 to#62;autolite 52 plugs,accel super stock suppression 8mm wires, and an accel electronic distributor set at 10 degrees initial,10 degrees in an adjustable vac,and 18 degrees mechanical for a total of 38 degrees,and an accel coil specifically for the dist.Any suggestions for a timing curve would be appreciated.
