Chevy 350 Timing - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-22-2006, 10:15 AM
Chevy 350 Timing
We are trying to set the timing on my street rod. The #1 piston is at the top of the compression stroke; the timing mark is on the pointer at about 2 degrees advanced; we adjusted the distributor and set the rotor arm right at the #1 contact. When we start the car and put the timing light on it, the timing mark ends up on the other side of the water pump @ about 25-30 degrees retarded! Obviously, we cannot rotate the distributor enough to compensate and get the timing mark back on the pointer. What do we do next?
Old 01-22-2006, 10:28 AM
Chevy 350 Timing
What is the firing order for a post 86 Chevy 350? I want to be sure I did not screw it up when I put the distributor back on.
Old 01-22-2006, 10:30 AM
engineczar's Avatar
actually that would be advanced if it was on the other side of the water pump
make sure the vacuum advance is disconnected and plugged if there is one, see if you can get the timing down to the 10-14 (or less depending the distributor) advanced range and set your idle speed. You should be able to turn the distributor 15 or so degrees unless the vacuum pot hits the manifold
engineczar's Avatar
1,8,4,3,6,5,7,2
Old 01-22-2006, 10:31 AM
If this is a typical SBC with the timing tab on the driver's side the timing would be advancing if the mark moves up towards the water pump (CCW). 25 to 30 advanced would not be unusual.
Old 01-22-2006, 10:51 AM
Chevy 350 Timing
If 25-30 degrees advanced is not unusual, how do I time the engine using a timing light? Does it mean I cannot use the timing pointer on the drivers side? Do I not worry about where the marker is and time it "manual" (retard to barely running and then advance to a good idle).
My other problem is that the distributor will only rotate about 12-14 degrees before it hits the accelerator cable mount on the firewall (I hope that's not a biggy since I would have to relocate the pedal assembly to change it).
Old 01-22-2006, 01:01 PM
[QUESTION=KONADOK] If 25-30 degrees advanced is not unusual, how do I time the engine using a timing light? Does it mean I cannot use the timing pointer on the drivers side? Do I not worry about where the marker is and time it "manual" (retard to barely running and then advance to a good idle).
Old 01-22-2006, 01:10 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Due to something called rotor phasing....
the rotor does not necessarily point directly at the distributor terminal when the spark fires.. some rotors have very wide contact ends...
What you need to do is remove your distributor and turn it one tooth and reinstall it so that your "timing" position will be in the mid range of your available distributor turning arc. That is.. you don't move the cable mount, you change the distributor....... move it so it won't hit the stuff!
You should also verify the TDC timing marks on your dampner and pointer by staticly checking the top dead center with a positive stop tool.
Old 01-22-2006, 01:30 PM
vacume adance
when setting the timing plug off the vacume advance
Old 01-22-2006, 01:40 PM
poncho62's Avatar
Wiki Edits: 5
Are you sure that you have the right damper on it?.....The early 80s SBs had the timing mark right on top, so you looked down between the water pump outlets.
Check your damper for TDC (top dead centre)
Old 01-22-2006, 08:05 PM
Chevy 350 Timing
Aloha xntrik, poncho82, onovakind, engineczar
Thanks for all the good help. The tip on "rotor phasing" I think it helped the most. I moved the distributor over one notch on the oil pump drive. The timing mark is now about 8-10 degrees closer to the pointer, almost straight up and almost hidden by the water pump. I am checking it at around 800 - 1000 rpm with the vaccum advance disconnected and plugged. The motor runs better.
My next move is try "manual timing". Here's how a friend explained how you do that:
1.) retard until it runs rough at idle,
2.) advance to where it smooths out,
3.) run to 160F - 180F and listen for pre-ignition pings going uphill in drive,
4.) if there is pinging, retarded it a degree or two.
Two questions:
1. Is that a good way to do it?
2. Would moving the distributor another notch make things better yet or would it make them worse?
konadok
Old 01-22-2006, 08:40 PM
57 Chevy's Avatar
Daryl
Location: Montana, now Arizona.Now Colorado. Wish I was back in Montana
Worse.
If you have a vacuum gauge, advance the timing to the highest reading at idle. Back it off if it pings. If your motor is built on the wild side, this won't work. You didn't say what cam, carb, ect. your running.
El Camino Engine - 350 Chevy or 455 Pontiac bjam2 Engine 16 08-07-2007 03:45 PM
El Camino Engine - 350 Chevy or 455 Pontiac bjam2 Engine 17 01-06-2007 09:11 PM
inital timing chevy 350 jerry gramlich Introduce Yourself 2 10-10-2004 09:18 AM
Timing Specs for chevy 350 engine 68_Convertible Engine 3 11-25-2002 05:51 PM
chevy 350 timing ron2424 Engine 4 11-05-2002 08:20 PM
