chevy 350 timing - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-07-2006, 08:53 AM
stanjr41's Avatar
chevy 350 timing
I finally got rid of all the gremlins and am ready to set things right.The drivetrain consists of a rear end/with approx. 3.90 gears;a 350 turbo trans.The engine consists of a 260 h.p. g.m. goodwrench longblock,w/a performer manifold;a 600 holley carb/with jets changed from #64 to#62;autolite 52 plugs,accel super stock suppression 8mm wires, and an accel electronic distributor set at 10 degrees initial,10 degrees in an adjustable vac,and 18 degrees mechanical for a total of 38 degrees,and an accel coil specifically for the dist.Any suggestions for a timing curve would be appreciated.
Old 02-07-2006, 10:01 AM
johnsongrass1's Avatar
Race it, Don't rice it!
All in by 2800
Old 02-08-2006, 07:56 PM
Rhansen's Avatar
Footbraker
10 deg. initial and 18 mech. will only give 28 at WOT. I'm sure your motor could handle 36 (or more) at WOT. This would mean setting initial at 18 (unless your mechanical adv. is adjustable) and having up to 46 while cruising. I used to run 16 initial with 20 mech and 10 vac on a mild SBC (~285 hp) no problems. I ran the vac adv on full manifold instead of ported so it would see 26 deg. at idle. It saw better mpg and eliminated a "flat spot" in the throttle transition switching from the ported source to full manifold vac.
El Camino Engine - 350 Chevy or 455 Pontiac bjam2 Engine 16 08-07-2007 03:45 PM
El Camino Engine - 350 Chevy or 455 Pontiac bjam2 Engine 17 01-06-2007 09:11 PM
inital timing chevy 350 jerry gramlich Introduce Yourself 2 10-10-2004 09:18 AM
Timing Specs for chevy 350 engine 68_Convertible Engine 3 11-25-2002 05:51 PM
chevy 350 timing ron2424 Engine 4 11-05-2002 08:20 PM
