chevy 350 tpi rebuild - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-25-2011, 12:24 PM
i need some help with a few things im building a 1990 350 roller block for my 86 camaro i have already had it cleaned and bord to .030 over and the pistons im using are speedpro hypeutectic .125 dome i have a set of heads im not sure i should use the casing on them are 14101083 will the work ok with the pistons i have?
Old 02-25-2011, 02:29 PM
DoubleVision's Avatar
Why do you need dome pistons? What is the rest of the combo? Will this be for street? race? 14101083...87-up...350..........Gen.I, also used on crate motors, 285 or 300 hp, 64cc chambers, 72' center manifold bolt angles
dome pistons and 64cc chambers will put the compression ratio up around 11:1 which won`t work on pump gas.
Old 02-25-2011, 03:16 PM
86 camaro
yes its going to be on the street mostly i have a few friends that are running 11:1 compression on pump gas and there have no problems
Old 02-25-2011, 03:22 PM
what cam are they using, what cam are you using?and are you using the stock tpi setup and if not stock what do you have
Old 02-25-2011, 05:14 PM
86 camaro
im not sure on cam there using but i plan on using comp cam cs 280xfi hr 13
one thing i found out was they had aluminum heads and i planed on using cast so i may have to fined another set of heads any ideals on what ones to go with that are center bolt valve covers
Old 02-25-2011, 05:18 PM
you wont be using the tuned port injection will you?
Old 02-25-2011, 05:22 PM
86 camaro
yes its tpi
Old 02-25-2011, 05:33 PM
just an fyi tpi is only good for 5500 rpm at best, go performer rpm and carb, just seems to me your building for a little more than the tpi is capable of giving you...
Help 88' Chevy 350 rebuild??? Showa72 Engine 21 02-25-2010 06:20 AM
'65 Chevy C-10 rebuild.. luvinmy65 Hotrodding Basics 1 01-20-2009 03:13 PM
Chevy Rebuild FLIGHT MECH Introduce Yourself 3 06-24-2007 11:35 PM
Chevy 307 Rebuild bigdome16 Engine 5 01-13-2007 11:45 PM
72 chevy rebuild HalfCutSkeleton Engine 3 01-22-2005 10:23 AM
