Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - chevy 350 to trans am motor mounts
Old 03-08-2009, 12:51 PM
dedub dedub is offline
80 SS El Camino
A technique I have used but not on a trans am is to bolt the motor to the tranny, place it on the crossmember and bolt it in, then lower the motor (WITH the Chevy motor mounts) down, Where they land is where you drill holes. You may be lucky and there will be holes pre drilled, going from a B.O.P set up to a chevy shouldn't be that far off.
