chevy 350 to trans am motor mounts
i have a 77 trans am and a recently purchased chevy 350 from an 80-85 truck to put in it, are there any websites that would have the correct motor mounts id need that would fit my motor and bolt into the frame? thanks
Use Camaro mounts....same frame
Ontario Rodders |
Usually this is a bolt in swap.
I swapped a 301 out of a '79 Firebird and replaced it with a 400 chevy. For whatever reason the passenger side of the crossmember was drilled for chevy motor mounts and the drivers side was not. Do as suggested, bolt the upper and lower motor mounts to the block and lower the engine into the car. If the appropriate holes are there, its a bolt in deal. Otherwise, scribe the location carefully and drill new holes. |
| DEBATE: Which heads are better?....Chevy 350, Pontiac 350, Olds 350 or Plymouth 350. | Steve-0321 | Hotrodding Basics | 21 | 11-26-2007 12:44 AM |
| El Camino Engine - 350 Chevy or 455 Pontiac | bjam2 | Engine | 16 | 08-07-2007 03:45 PM |
| El Camino Engine - 350 Chevy or 455 Pontiac | bjam2 | Engine | 17 | 01-06-2007 09:11 PM |
| Turbocharging a 350 chevy | radracer43 | Engine | 4 | 09-25-2005 07:30 PM |
| 350 buick in chevy truck? | jrm123180 | Engine | 7 | 04-03-2004 11:03 PM |
