Chevy 350 Tune-up - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-23-2009, 08:17 AM
Last journal entry: 1955 Chevy Convertible
Chevy 350 Tune-up
I'm sure this is a rather simple question but I don't know the answer. Should I do the timing first, adjust the Idel first, or the vacum. Also where do you hook up the tach on a car with electronic ignition. I just got my motor running last night in a 55 chevy. sounds good. But now I need the fine tunning. Thanks Nick
Old 05-23-2009, 09:21 AM
Speedshift_Sam's Avatar
Mekanicus Automotive Group
What to start with
She runs well eh? Great! Okay, first off, what type of electronic ignition? Some have a blade connector right on the distributor cap specifically as a tach output. Set the idle by ear to start with, what sounds good is usually close enough. Then go on to timing.
Old 05-23-2009, 09:38 PM
Yes, Runs great. Your right, I timed it today after getting the car at running tempature. Was a little off yesterday but got it 4 degrees before top dead center. Than adjusted my vacum was around 19-18. Ideld smooth. I think I might have screwed up my starter or fly wheel. Darn Igintion switch wasn't spring back to disingage the starter. Never had headers on a car before and that noise that was coming from the that side of the car was really the starter or flywheel grinding I thought thats how headers sound. O well once I figured what that noise was perred like a kitten. What a difference. I think I might have also put a little to much transmisson fluid in. Any suggestions how to remove like a extra qt. Thanks for you reply Nick
Old 05-23-2009, 10:25 PM
fast68's Avatar
likes chevy trucks & boobies
disconnect trans cooler line at radiator and let it pump out a quart or so.,
have someone in the car to shut it off for you real quick.
1/2" wrench loosens the line fitting on most 5/16" steel tubing
spray with penetrating oil to make sure the line doesnt spin with the fitting and kink the line
good luck!
Old 05-24-2009, 08:41 AM
Thanks alot never thought of letting fluid out that way.
Hi. just wondering why the 350 chevy small block is so good... judgedredd Hotrodders' Lounge 78 06-25-2010 08:01 AM
350 chevy help joesnova2 Engine 7 11-08-2009 05:46 AM
350 or 383 for 1963 Chevy Truck abeis Engine 6 03-12-2009 02:19 AM
350 Chevy in a '73 TransAm Lawngodfather Engine 6 06-10-2008 08:08 AM
El Camino Engine - 350 Chevy or 455 Pontiac bjam2 Engine 16 08-07-2007 03:45 PM
