Chevy 350 valve adjustment - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-11-2011, 05:46 PM
Hey everyone. I am building my first Chevy SB. I have a 4bolt main block with 1 piece rear seal. Believe it is an '86 block. Installed 882 heads that have been professionally built with Z-28 springs. The new cam is a Summit 1 step above stock with matching hydraulic lifters. I bought new pushrods of standard length. I am using a book by Larry Atherton to assemble this engine. When following his recommended technique for adjusting valves (seems like there are a dozen or so methods) When I complete the cycle of rotating the engine, starting at TDC on #1 cyl. and go through the sequential valve adjustment, each one tightens up nicely as I make the adjustment, but when I am finished, I end up with several loose rocker arms - loose to the point that they wobble on the stud.
I do not yet have oil in this engine, since it is a fresh rebuild and has not yet been started. I am thinking that the lifters are not holding pressure, thus causing the loose condition. Or perhaps, the pushrods are not long enough. Obviously, I am stumped, so any help is greatly appreciated.
Thanks. Hope to hear from you soon!
Old 09-11-2011, 05:51 PM
mud.man.rj's Avatar
If you adjusted as stated then you are right and will have a few loose rocker arms and once running will fill the lifters with oil and the adjustment will be correct.
After you adjust a valve then turn the motor over, some of the adjusted valves will be pushing down on their lifter. Since there is zero oil pressure the force of the valve spring will collapse the lifter and bleed the oil out. Then as you rotate it over again and that particular lifter is on the base circle, there will be some lash since there is not enough oil in the lifter to take up the slack.
Old 09-11-2011, 10:30 PM
350 SBC valve adjustment
Prime the engine oiling system before you try to start the engine. Have someone rotate the engine by hand while you prime it. And be sure to break in the cam correctly.
Ron
chevy 230 L6 Valve adjustment lt1tyrell Engine 3 11-09-2010 04:53 PM
Need help with valve adjustment chevy 350 chevysnharleys Hotrodding Basics 15 03-18-2009 07:28 PM
73 chevy 454 valve adjustment heinzeroth Engine 3 10-04-2003 01:58 PM
chevy valve adjustment derrick1977 Engine 6 12-23-2002 05:21 PM
BB Chevy valve adjustment R2SPEEDRACER Engine 1 05-28-2002 07:15 PM
