Chevy 350 valve adjustment(new roller rockers) - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-25-2011, 08:50 PM
Alright so Ive got alot buttoned down to where im likin' things but just got new roller rockers, electric fuel pump and reg, since the mechanical pump is crankin out +14! Anyway just want to make sure im doing this right:
Leaving the intake manifold on since there are zero leaks basically all i can do is watch the pushrods right?
1) get motor to TDC and i can do cylinder #1
2) I can just watch my push rods and they should drop down in firing order and I can the do each cylinder as each pushrod falls down and should be done in one full turn to aviod rubbing off too much of the cam and crank lube.
Correct?
Old 08-25-2011, 11:15 PM
I would never set valves using the cylinder at TDC method, why? because of the overlap of a camshaft, the two valve being open at the same time for a short period..The best method i think is to do the E.O.I.C Exhaust open, Intake Closed.. Do one valve at a time one cylinder at a time weather you are using a hydraulic or solid lifter cam.. Basically as the exhaust valve begins to open, set lash on intake side.Then rotate engine.. As the intake valve opens, then begins to close, as the intake valve is almost closed, set lash on the exhaust valve..This way you know your getting the lifter on the heel of the cam lobe for proper lash adjustment. There are many other ways guys use to set lash that work, But this method is I think the easiest way to understand it for most..
Hope this helps
Old 08-26-2011, 12:29 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
There's a Crankshaft Coalition article on the EO/IC Method (Exhaust Opening/Intake Closing) procedure HERE, including instructions on how to make yourself a timing tape and how to be sure your timing marks are correct.
Old 08-26-2011, 04:39 AM
Seems to be alot of different opinion on this! I just went through the same thing with my build. I ended up using the TDC method. But I haven't fired it up yet to tell if it's ok. Fingers crossed! The TDC method just seems more simple to do and easier to understand.
Old 08-26-2011, 11:19 AM
it may seem easier, but you have to understand depending on your overlap in your camshaft, the exhaust valve may not be set exactly the way it should be leaving a bit loose, you might be-able to get by a bit on a hydraulic lifter as there more forgiving, but solid lifter... NO WAY will the lash be right using the TDC method, you could be off your lash as much as 15-20 thou
Old 08-26-2011, 03:32 PM
I just did the firing order method on my build 350 sbc oem roller style setup and just got it done this weekend and it was just fine. I am running a hydraulic roller cam though as stated anything mechanical cam you really have to be correct on things. I just got my engine on tdc compression stroke on number 1 cylinder and adjusted both valves then did a quarter of a turn next set of valves in firing order etc. I do the pushrod up and down method not the spin method as it can be really hard to tell when you get zero lash as I learned from my past mistakes and its easy to over tighten valves and have them open. I do zero lash then a half turn past and tighten them down and lock them as I am using full rocker arms. Hope that helps.
Eric
Old 08-30-2011, 11:12 AM
Eric
Exactly
If you're using hydraulic lifters, and a feeler gauge v.s. Waiting for chatter to go away you'll be pretty darn close using TDC method.
Youtube search-" boxwrench-valve adjustment" I haven't had any problems.
roller rockers and valve covers candrive55 Engine 4 04-05-2010 04:19 PM
roller rockers/valve covers 65ELCMO Engine 11 01-28-2010 03:27 PM
Roller rockers/stock valve covers BBC Fairlane514 Engine 2 10-03-2008 03:00 PM
Roller rockers under stock valve covers curtis73 Engine 4 11-19-2006 06:53 PM
Solid roller valve lash adjustment snod83 Engine 2 05-10-2004 08:08 PM
