chevy 350 valve retainer question. - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-29-2014, 04:43 AM
Hi, im going to replace my valve springs and retainer.
I have ordered a summit sbc spring and retainer kit.
Should i use the old retainer with some kind of shield on i think it is exhaust valves. Some kind of cover over the spring. I think you no what i mean. Or should i use the new retainers in the kit.
/Magnus
Old 04-29-2014, 10:16 AM
Is this what you bought?
If so, you should use the springs, retainers , locks and seals that came with the kit.
Old 04-29-2014, 10:23 AM
Yep, its that kit. Ok thanks alot
Old 04-29-2014, 06:26 PM
BOBCRMAN@aol.com's Avatar
You did not state which heads you have. Stock SBC heads have rotators on the exhaust side.. That kit will not work out of the box.. You have to shim the exhaust spring seats as they are deeper than the intakes to allow for the rotators with the thicker tops and the same length springs, intake and exhaust..
No shims= no spring pressure.. Get a handfull of asst. .015-.030-.060" spring shims and set all spring heights the same.. Do not use the stamped "shields".
The Following User Says Thank You to BOBCRMAN@aol.com For This Useful Post:
gonaker (04-30-2014)
Old 04-30-2014, 01:01 AM
Ok, that didnt sound so good Its 1989 TBI heads. xxxxx183 or something like that. Do i need to shim my springs with these TBI heads?
Old 04-30-2014, 05:04 PM
You will need to shim the spring seats on the exhaust valves. To bring them up to the intake s-seat height. Actually ALL spring heights should be checked and set to the spring seat spec pressures..
The Following 2 Users Say Thank You to BOBCRMAN@aol.com For This Useful Post:
gonaker (05-01-2014), jmt455 (05-01-2014)
th350c valve retainer help fast68 Transmission - Rearend 5 07-24-2009 04:00 PM
valve spring retainer question ap72 Engine 3 11-23-2008 10:30 AM
Valve lock/retainer wobble ssmonty Engine 5 08-23-2008 04:53 PM
Valve Spring Locator, Retainer Clearance Specs SSedan64 Engine 5 06-10-2008 03:49 PM
measure valve lift at retainer GMR Engine 9 05-26-2008 08:13 AM
