chevy 350 vortec heads ....wat cam?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-31-2007, 12:05 PM
47chevrolet's Avatar
BuRnIn RuBbEr
Last journal entry: 350
1970's chevy 350 four bolt with vortec heads. .30 over...What size carb and cam ?
Old 08-31-2007, 12:50 PM
383silverado's Avatar
you will need a vortec style intake manifold.
what compression ?
roller or flat tappet ?
if you don't know what year is the block ?
600 0r 650 will do
and what is it going in ? car or truck
street strip, week end warrior, daily driver
do you want bottom end power or top end.
Old 08-31-2007, 01:04 PM
DoubleVision's Avatar
We also need transmission, rear gear ratio, how is it to be used? street? strip? daily driver? If you can give the entire engine detail. We can`t guess what you want it to do with no information, not being harsh, just being honest.
Old 08-31-2007, 01:33 PM
I concur and toss in the tire size while your at it
Old 08-31-2007, 03:09 PM
xbody69's Avatar
CARNUT
vortexed
Bud Your Gonna Hafta To Give It Some Serious Thought Before You Throw Out Such A General Question To Such A Vast Audience Of Opinions And Experiences. Unless You Know Exactly What The Intended Purpose Of The Engine In Question Will Be, You Are Gonna Get About 100 Different Options From About 30 Different People.
Old 08-31-2007, 04:42 PM
You will need 8 to 10 degrees more duration on the exhaust than intake due to the vortecs poor flowing exhaust port.
gear, stall, compression, and cam all must match
for example, in general for sbc's:
gear from 2.73 to 3.30: use 8.5 to 9:1 cr, stock stall, 200 to 212 degree cam
gear from 3.30 to 3.60: use 9.0 to 9.5:1 cr, 2200 stall, 212 to 222 degree cam
gear from 3.60 to 3.90: use 9.5 to 10:1 cr, 2600 stall, 222 to 236 degree cam
gear from 3.90 to 4.20: use 10.0 to 10.5:1 cr, 3000 stall, 236 to 248 degree cam
gear from 4.20 to 4.50: use 10.5 to 11:1 cr, 3500 stall, 248 to 260 degree cam
For heavy cars use the smaller cam in the range. So, if you have a truck with 3.55 gears then use a cam with 212 degrees duration at 0.050". Plus, when it comes to cams, it is always better to error on the small size.
**** Disclaimer ****
These are just general guide lines, opinions will vary.
Old 09-04-2007, 12:09 PM
BuRnIn RuBbEr
motor
rear end gear 3.73.. tranny th350...weekend warrior... going into a 93 s10 shortbox
Old 09-04-2007, 03:28 PM
I would use a cam with 230 to 232 degrees on the intake and 238 to 240 on the exhaust with 110 lsa. 10:1 cr with 2800 stall. Performer RPM intake with a Holley 750 DP. 1-5/8 full length headers with 2.5" mandrel bent exhaust with a X-pipe and Hooker Aero-Chamber mufflers. HEI with msd conversion, 20 degrees initial and 35 degrees total timing. If it is too loud, install a few dynomax bullets before or after the main mufflers.
Old 09-04-2007, 03:52 PM
Still need more info, without the specs of the rest of the engine it`s shooting in the dark. I won`t recommend a cam for nobody if I don`t even know the compression ratio, the intake, headers, Ignition, timing components, pistons used and etc. If you call a cam company and ask them to pick a cam for you they will ask you all the above specs and if you don`t know the specs or give them they will not suggest a cam, they`ll tell you the exact same thing I just did. Without knowing the combo is almost like sticking a big cam in a stock 305 and wondering why it don`t run worth a flip. Do you have a converter picked out to run with a larger cam? the stock converter won`t even let it idle past a certain point of duration so a looser converter is called for. If I recommend a cam on the info you`ve given and it won`t idle or have any power until it`s revved you will not be happy and you will blame us for recommending a bum cam when we didn`t even know the specs.
Old 09-04-2007, 04:12 PM
techinspector1's Avatar
Wiki Edits: 326
You tell 'em DV. I concur.
Ported & Milled vortec heads on stock 350 automotive breath Engine 23 11-18-2006 03:07 PM
XE274H cam sound like? Heads Choice? Help me decide on combo for chevy 400 Warrant Engine 10 03-01-2006 03:58 PM
Cam for Chevy 350? Mike_82 Engine 14 07-25-2004 03:56 PM
383-- use the vortec heads? what cam? slonova Engine 10 02-02-2004 12:45 PM
91 Chevy 350 to go vortec? bluechev4x4 Engine 9 12-12-2002 06:15 AM
