Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - chevy 350 w/ mild cam.. idle/gear probs
  #16 (permalink)
Old 02-21-2012, 04:01 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
If it has a long duration cam you will never get it right untill you address the distributor advance curve. A low stall converter will not allow an engine to idle correctly in gear if the cam is big.
fix the distributor
Cam or converter swap, pick one.
