Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - chevy 350 w/ mild cam.. idle/gear probs
  #18 (permalink)
Old 09-26-2012, 05:46 AM
foodstamp's Avatar
foodstamp foodstamp is offline
poor boy's racing
small update after MIA
well i know its been a while since i last posted, ended up putting truck in the shop. carb issue never got fixed, but found out what cam was in it... it had a 292 comp cam... with 2 lobes completely wore off, 2 lobes thatrounded smoothly... so i had a howards cam and lifters installed. cam specs are
Strong Low & Mid-Range Torque
.447/.447 lift
280/280 in/out
208/208 in/out @050
111 lobe seperation
lifters came with the cam, says they are matched, but i think its more snake oil than anything...
a few more details about engine/trans: 3970010 block punched 30 over, the new cam/lifters,1.6 rollers,small camel hump heads and a 700r4 trans.
hope this helps
